engine bogs down and then dies
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Yesterday I rode my bike and everything went well and I had no problems at all. This morning I rode ...
Old 07-02-2008, 11:44 AM
Default engine bogs down and then dies
Yesterday I rode my bike and everything went well and I had no problems at all. This morning I rode my bike and after about a mile of riding, the motor starts cutting out and losing power and sounding like it's running out of gas. If I use the throttle just a little bit 1/4 turn it runs a little bit but eventually dies. Anything over 1/4 throttle and it sounds like it is flooding out.
I'm not very mechanical so I may not be explaining this good. If you need to ask me questions please do.
It's been doing this for a while and I'm at a loss for what to do. I thought it was fixed when I changed the idle screw and finally got it to idle yesterday. It ran great yesterday all day long. I took several 10 mile trips with no problems at all. I'm getting ready to take it out for a spin again and I will let you all know how it goes.
thanks,
cd
70cc HT
Moon Dog
crabdance@gmail.com
Old 07-02-2008, 12:11 PM
misteright1_99's Avatar
Default Re: engine bogs down and then dies
Check your float. Sounds like the same problem that didnt go away.....
Old 07-02-2008, 07:18 PM
Norman's Avatar
LORD VADER Moderator
sounds to me like your starving for fuel. do you have an inline fuel filter?
Did you leave the intank fuel strainer on or remove it?
Now for something to try and it will sound kind of kinky take off the gas cap and pressure up the tank by blowing air into the tank with your mouth. see if it will now run. Your tank may have some boogers in it if that pressuring up on the tank helps.
if you don't have an inline filter do get one.
I told you it would sound kinky and I realy toned it down at least I tried to.
Norman
norms-iron-works.tripod.com
Old 07-02-2008, 09:03 PM
tinkerfinger's Avatar
I had same problem, turned out the top of the carburator had simply come loose where you unscrew it to attach the cable. Air was pooring in around it.
Old 07-02-2008, 11:38 PM
Norman
I believe that the intank fuel strainer is still on. I will try blowing into the gas tank tomorrow and let you know what happens.
70cc HT
Moon Dog
crabdance@gmail.com
Old 07-03-2008, 12:32 AM
could be that your gas cap is sealing so well that no air can get into the tank creating a vacuum. Check it. If this is the case, drill a tiny hole just off the side of the rubber washer underneath. Enjoy the ride..
visit www.thatsdax.com for more !!
Old 07-03-2008, 04:39 AM
I guess there is one important thing that I failed to mention. When I turn the gas on at the tank, fuel starts leaking real bad. Not just a little but a lot. I don't know where the leak is yet but I will try and find that out later on today. Sorry to leave out such an important detail.
70cc HT
Moon Dog
crabdance@gmail.com
Old 07-03-2008, 05:01 AM
It is probably leaking at the brass fuel inlet that the fuel line plugs onto on the carb. It unscrewed on me and lost half a tank. unplug fuel line. you will see slots in top for flat head screwdriver.
  #9 (permalink)
Old 07-03-2008, 05:08 AM
Thanks tinkerfinger.. that might be it. That sounds like the most reasonable thing so far. Like everything else on my bike it probably vibrated loose. When it gets light outside I will give that a try. I will let you know how things go.
thanks
70cc HT
Moon Dog
crabdance@gmail.com
  #10 (permalink)
Old 07-03-2008, 05:49 AM
No worries, last night my bike shut down on me in the dark. I had purchased new dokker shorts, and when I simply cranked the peddals 1/2 turn to give my left cheek a rest, my pant leg flipped the fuel petcock off. I have an I.Q. of 156, and it took me a good 20 min to figure out what happened in the dark. I was grabbing hot metal parts to see if anything was loose, Total panic mode. I felt like an idiot when i realized the problem.
Even worse, it happened again on the way home. So much for baggy shorts. Its always something.
Advertisers
