I have poured though many posts but didn’t find a clear answer, I need a more experienced opinion.
My engine was running great when I last rode it a month ago and sheared the already upgraded rear mounting bolts. I decided to use that as an excuse to upgrade to the SPB shift kit. And I used buying the shift kit as the excuse to buy a nicer gas tank. I installed the shift kit and the tank and found much to my dismay; I can’t get the
booger to run. I am getting spark so that doesn’t look like the problem. Fuel is new and fresh from the pump that day.
My replacement gallon and a half tank didn’t come with a gas cap so I added some gasket material to the original tank cap to make it fit till the new one arrives from eBay. I considered that my homemade temporary cap might not allow it to vent but that doesn’t seem to be an issue because the cap wobbles and isn’t anything near airtight. I removed the cap while letting the fuel line flow into a catch tank and didn’t see any difference with the cap on or off.
It’s a 67 cc from Spooky Tooth with the CNS carb upgrade that worked flawlessly when I last rode it. With the shift kit I have to pedal the engine directly to start but I wasn’t able to get it to turn over. I did adjust the clutch to make sure that I was losing any effort due to clutch slip.
After a good 45 minutes of combined effort over several attempts I swapped the carb out back to the original carb that came with the kit. With the original I was able to get it to turn over a few times and run at low rpm’s. It looked like it was blowing smoke out at the head gasket so I tightened it. I can occasionally get it to run at say 1000-1500 rpm if I give it too much gas it stalls, too little and it also stalls.
So here is what I’m thinking, if both carbs were working fine when last used, both didn’t go bad at the same time. Fuel /oil mix and spark are not issues. The exhaust is a SBP expansion exhaust and it worked great when I last rode it. Other than the possibility that the intake manifold or exhaust pipe had something fall into them while they were on the work bench that is blocking the airflow, I am totally stumped.
I plan on taking the intake and exhaust off tonight to see if it could be that simple. But I kind of doubt it. Any suggestions?
