Originally Posted by fairracing31 Are you having alignment issue's? Is your rear sprocket "True" with your front sprocket? You should have 1/2-3/4inch slack in the chain. |
I have closer to 2 inches. Odd, seeing that if I took out the next link, it would put the axle outside the housing. And with the chain cut where I have it, I can't move the axle back far enough.
Originally Posted by fairracing31 Yes the rubber should sandwhich the spokes |
Thanks, most illustrations I have seen were taken @ odd angles and I couldn't tell the reflection from the real item. Plus the instructions I recieved were quite vauge.
Originally Posted by fairracing31 |
Well, now that I see I can swap around my teeth to face inward, I might try that, seeing that my chain wants to travel the inside of the sprocket anyways.
This wasn't a standard sprocket, did you reduce the number of your rear gears to be single?
