Stock Market Cats Alternative Energy
Clutch Stuck in engaged position
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I have an 80cc raw motor with the clutch stuck in the engaged position. I haven't seen any posts on ...
  1 links from elsewhere to this Post. Click to view. #1
Old 12-01-2009, 07:13 PM
Default Clutch Stuck in engaged position
I have an 80cc raw motor with the clutch stuck in the engaged position. I haven't seen any posts on this yet so if there is one I hope you'll forgive me! Are there any suggestions out there. Thanks guys and gals.
Old 12-01-2009, 07:59 PM
motor_head's Avatar
Default Re: Clutch Stuck in engaged position
cable broke or stretched
Old 12-01-2009, 08:30 PM
Thanks motor head. I rechecked the cable and it is fine. There is a pin that seems like it should move in and out to engage and disengage the clutch. The pin is in the shaft that the small sprocket is on, that comes out of the motor itself. It seems like the pin should get pushed in when you pull the clutch lever, but it is stuck in the out position.
Old 12-01-2009, 09:46 PM
2door's Avatar
How are you trying to push that pin in? You won't be able to do it with your hand or fingers. The clutch actuator is supposed to do that. The actuator is the cam inside the clutch actuator cover, left side. Are you sure you have the clutch cable adjusted correctly? It should have little to no slack where it is attached to the clutch actuator arm on the engine. If this is a new engine then the clutch might be stuck from the factory. Try striking that pin with a good blow from a plastic headed hammer. Don't beat it to death just give it a good solid hit and see if it frees up the stuck clutch friction pads. Get back to us if these things don't help.
Over Youth and Skill
Old 12-01-2009, 10:16 PM
Take the clutch sidecover off and tap arround the flower nut to release the seized clutch plates
Old 12-01-2009, 10:46 PM
Hey Worked like a charm! I tapped it a bit from both sides and now it's flawless. Thanks guys. Made my evening!
Old 12-02-2009, 12:57 AM
If you are the same "wishesdontdodishes" from that other bike forum, i'd be curious to see how you attached the motor to your unicycle. Please post a video... it sounds pretty dangerous, so be careful!
Old 12-02-2009, 02:14 AM
There's a topic for another forum, but to answer your question I never got it to work predictably. It's a shame too. Several NBA teams and a Vegas casino were offering appearance money. I say good luck to anyone getting a gas powered unicycle to work before the old lady throws you out. My advice...feather that throttle.
Old 12-08-2009, 04:02 PM
Sorry, I have the same problem. Did you tap the pin or the flower nut? Where is the flower nut?
Old 12-08-2009, 10:26 PM
2door's Avatar
Setmea,
The pin is in the center of the engine drive sprocket, left side of engine behind the clutch actuator cover. The flower nut is behind the right side engine cover, rear, center of clutch pressure plate. Tapping either will usually release a stuck clutch. Make sure that your clutch cable is adjusted correctly also. It should have little to no slack in it where it attaches to the clutch actuator arm with the clutch lever (on the handlebar) is released.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f34/clutch-stuck-engaged-position-13388.html
Posted By For Type Date
gary.robertson's Bookmarks on Delicious This thread Refback 12-17-2009 07:13 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92
