Clutch Seized??? Help!!!
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Just got my new 70cc engine today from Dax. I tried to disengage the clutch but it wont give. The ...
Old 09-06-2008, 08:59 PM
Motorized Bicycle Apprentice
Exclamation Clutch Seized??? Help!!!
Just got my new 70cc engine today from Dax. I tried to disengage the clutch but it wont give. The engine does turnover by hand and sprocket does move.
Old 09-06-2008, 09:24 PM
Spunout's Avatar
Dealer
Default Re: Clutch Seized??? Help!!!
you mean, the bike will still roll forward/backward with the clutch released? have you checked the clutch cable adjustments?
i had a problem with an engine, that the woodruff key that holds the drive sprocket onto the shaft went awol.
have you called duane (dax)? he's pretty good at dianosing problems and assisting you over the phone.
good luck
New, fully assembled motored bikes here:
http://blog.360.yahoo.com/blog-Pujq1...GhLe0AOJ3?cq=1
(401)952-7064
"sn0rk." (Dan)
Old 09-07-2008, 09:26 AM
Bikeguy Joe's Avatar
MODERATOR
You are saying that the clutch doesn't disengage?
Adjust the adjustments on the cable halfway in on both ends, loosen the cable end piece, push the lever over tight, then tighten the cable end down tight while holding it against the lever arm.
Adjust the cable end adjustments until there is 1/16"-1/8" of freeplay in the lever end.
Advertisers
