Clutch Gear Chatter
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Howdy all, While cleaning the clutch pads, I noticed the large gear was "floating" (it had more play ...
Old 04-23-2009, 11:37 PM
Default Clutch Gear Chatter
Howdy all,
While cleaning the clutch pads, I noticed the large gear was "floating" (it had more play than I would have expected). I could push it forward and aft or up and down. I think this is where I am getting the chatter. It appears to have all the ball bearings (I could see them a bit and there were no spaces). How much play is normal and who much is too much??
Thanks,
j
Between Bikes
Old 04-24-2009, 07:38 AM
Creative Engineering's Avatar
MANIC Mechanic
Default Re: Clutch Gear Chatter
Originally Posted by FlyJSH View Post
Howdy all,
Thanks,
j
J,
No more than .005" radially. Ideally it should be .0002-.0005". It is very important that the gears mesh precisely at the diametral pitch. I have had a dozen or so of these engines apart, and so far only 1 had a really good bearing set.
If your gear is excessively loose, it will best to fix it now before any real damage is done.
Jim
Old 04-24-2009, 08:43 AM
Just to clarify, the gear is only loose and chattering when the clutch is disengaged. When engaged, it feels nice and tight.
okay, so what is a good fix?
Between Bikes
