| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | chain tension Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. a constant prob. i have is the cheap- #$%@&%$$#!!??-chinese chain tensioners.anybody come up with a better way?-thanx-...  |
09-26-2009, 08:15 AM
| | Motorized Bicycle Member | | Join Date: Jul 2009 Location: montana
| | chain tension a constant prob. i have is the cheap- #$%@&%$$#!!??-chinese chain tensioners.anybody come up with a better way?-thanx-G.Z. |
09-26-2009, 09:39 PM
| | Re: chain tension Glenz,
How handy are you? Do you weld or have access to a welder or a friend who does?
Personally I have three bikes, one has over 1500 miles on the kit chain tensioner with no problems. The tensioner needs to be secured to the chain stay so it can not rotate into the rear spokes and the bracket given a slight twist to align the wheel with the chain correctly, but there are other alternatives. Here are two views of two different approaches to the tensioner issue.
Over Youth and Skill |
09-26-2009, 11:49 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: Oshawa
| | Re: chain tension Hello, I like your tensioner ideas. The second one is awesome! My tensioner stripped somehow WHILE I was riding, and loosened the chain a whole lot, which made it hit inside the casing, and snapped one side of my #41 chain!!!! I'm a cursed rider who has a break down EVERY time I ride. I've had everything go wrong, including a snapped frame. I can't begin to express my frustrations, and I literally want to give up on motor bikes. Here's my question, can I use a rear derailler from another bike as a chain tensioner with a #41 chain? And how would I do that? If you can help, that would be excellent, I need this repaired AGAIN asap. Thank you. |
10-04-2009, 11:24 AM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Indiana
| | Re: chain tension try the chain tensioner and spring from tractor supply mention in other posts, i used the cheap chinese bracket with new automotive bolts and lots of thread lock, works well now.
to keep the tensioner wheel from sliding down in the slot i added a extra bolt in the slot as a block.
also used some teflon tape where the tensioner turns on the bolt. |
10-04-2009, 11:32 AM
| | Re: chain tension thats a good idea drilling a hole to keep it from turning. mine got loose a couple of times till i switched to automotive grade bolts and used thread lock where the metal clamps to the frame. i was worried about weakening the frame by welding a cross piece |
10-04-2009, 02:01 PM
| | Re: chain tension Quote:
Originally Posted by Bmetz thats a good idea drilling a hole to keep it from turning. mine got loose a couple of times till i switched to automotive grade bolts and used thread lock where the metal clamps to the frame. i was worried about weakening the frame by welding a cross piece | Welding to the frame, if done correctly by a competent welder will not weaken, but will strengthen the frame. Underline "correctly" here. A bad weld can be a weak area and if the base metal, the frame, is not incorporated into the weld it can fail at that point.
10-04-2009, 03:48 PM
| | Re: chain tension i, personally, would never drill a hole in my chainstay.
and i dunno if i'm just lucky, but all the bikes i've built haven't needed a tensioner. i've changed out the rear sprocket or front chainring on the pedal side, added or subtracted chain links, spaced out the wheels, and spent a lot of time figuring out exactly where to put the motor to keep a straight shot.
i realize that this won't work for all bikes, and if i ever need a chain tensioner, i'll probably try to modify something like this: |
10-10-2009, 09:25 PM
| | Motorized Bicycle Newbie | | Join Date: Sep 2009 Location: Florida
| | Re: chain tension Try this. Just took the stock Chinese POS and put it on the top chainstay, and put a 10" or so bar stock from tractor supply and extend it to reach the proper length and either drill a hole or make a slot for the wheel to slide up and down. You can even connect it at the end to the frame or I've noticed it works just fine without doing that...
10-11-2009, 12:56 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: chain tension
10-13-2009, 04:39 AM
| | Re: chain tension You can also shim between rear motor mount and the seat post with some sheet aluminum to space the motor forward and eliminate the tensioner. You'd be suprized how much slack a 1/16" thick shim will take up.
__________________ Put something FUN between your legs.. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:03 AM. | | | Sponsors
