| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Chain pops constantly! HELP! Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Hi i have a problem... My chain pops constantly. Are there any sprocket alignment tips you have? Perhaps a new ...  |
04-26-2009, 01:49 PM
| | Motorized Bicycle Member | | Join Date: Oct 2008 Location: Pennsylvania, USA
| | Chain pops constantly! HELP! Hi i have a problem... My chain pops constantly. Are there any sprocket alignment tips you have? Perhaps a new hub with the sprocket attached? Mine just wont stay straight! Any suggestions?
Justin  |
04-26-2009, 01:59 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2008 Location: Virginia
| | Re: Chain pops constantly! HELP! Where in pa are you. |
04-26-2009, 04:04 PM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Las Vegas NV USA
| | Re: Chain pops constantly! HELP! get a clam shell sprocket adapter and a sprocket from Manic Mechanic you will have a perfect alignment SPROCKET ADAPTER |
04-26-2009, 04:06 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: Chain pops constantly! HELP! You should lift up the rear wheel and turn the wheel round and round until you see where the chain starts to go off track. You can also do this to see if the sprocket is wobbling. If it is wobbling I'd tighten the nuts on the spots that can use some pulling inwards towards the right. I'd also see if the chain is too loose and shorten the chain. A pic would help. |
04-26-2009, 06:53 PM
| | Re: Chain pops constantly! HELP! Nerever,
The kit supplied #415 chain can give you some problems. Check it closely for binding and either free up those areas or replace the chain with a good quality industrial #41 chain. This chain is available at Grainger, Ace Hardware, Tractor Supply and other industrial suppliers. I've experienced rough spots in the kit chain the will cause the problem you're having. I've seen rollers that wouldn't roll and even a kink (twist) in the kit chain. Also make sure your chain tensioner, if you're using one, is tracking true and not allowing the chain to run off to one side or the other. Most of the chain tensioner brackets will require a slight twist to align it perfectly with the drive and driven sprockets. With the chain removed, spin your rear wheel and watch for any wobble in the rear sprocket. It must run true to keep the chain running smooth. Use the advice above to make sure your sprockets are running true and wobble free. Hope this helps.
Over Youth and Skill
04-26-2009, 08:51 PM
| | Motorized Bicycle Member | | Join Date: Apr 2009 Location: Portland, OR
| | Re: Chain pops constantly! HELP! I have this same problem...:-( |
04-28-2009, 03:45 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2008 Location: North Carolina
| | Re: Chain pops constantly! HELP! My setup is wobbling like a bowl full of jelly!! Chain pops every once and a while. I just got my tax refund from the government (good sized check for once!!), I think I'll buy one of those nice clam shell adapters. This is an important safety issue and I'm tired of fighting the blasted thing.
__________________  If you hear something that sounds like angry bees in a coffee can, It's me riding my bike.
Chain:
#41 or #415
04-28-2009, 09:21 PM
| | Re: Chain pops constantly! HELP! I kinda remedied it by taking another link out of the chain, but now it's kinda tight... :-( So i was riding for a bit then the back tire popped! I don't know if that was due to the tight chain, but i'm beginning to think this bike is cursed! |
04-28-2009, 10:08 PM
| | Re: Chain pops constantly! HELP! I'm sorry your bike is giving you a fit. Hang in there! I've had the same trouble before.  Its a pain in the neck for sure, but you'll be alright.  if it gets on your nerves really bad, just take a break and try later (that's what I do when my patience runs out).
I want my bike to run perfectly, so I hope the clam shell adapter helps (couldn't hurt to try it). Not a bad deal for 51 bucks! The thing that keeps me wanting to invest in this bike project is the fact that there is tons of room for improvement and innovation (not to mention 150 MPG). You almost have to have a kind of faith and a will to see it through with these engine kits. It will work, Just give it some time.
Chain:
#41 or #415
04-29-2009, 01:25 AM
| | Re: Chain pops constantly! HELP! do not loose hope!!! I have finally fixed my issued. Here's what I did and hope it help you guys.
1) remove the rear wheel, check for axial and radial play on the bearing. It was loose and wobbling around causing the whole wheel to wobble in the first place. Which means that there's no way the sprocket would be straight/true. I retighten the bearing/axle.
2) reinstalled the sprocked but only tighten 1/4 turn at so as to minimize too much pressure at one location. (patient is key)
3) put the wheel back in and check for sprocket to stay true. tighten 1/4 of a turn on each nut at a time.....this step would reduced wobbling slowly until it is acceptable (~1.5mm of play)
4) reinstalled the chain and voila ... no chain popping off.. no weird noises..
just take your time one and you'll get it...I know it is a pain in theeee ****zzzzzz | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:21 PM. | | | Sponsors
