carby adjustment
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. Can anyone tell me by adjusting the float level in the carby does it change the mixture If it does ...
Old 10-02-2009, 01:50 AM
Default carby adjustment
Can anyone tell me by adjusting the float level in the carby does it change the mixture If it does wich way leans it and richens the fuel mixture thanks mick29
Old 10-02-2009, 02:02 AM
GearNut's Avatar
Default Re: carby adjustment
It in no way can replace doing it properly, IE: changing the fuel jet but....
Raising the float level can enrichen the mixture.
Lowering it can lean the mixture.
Old 10-02-2009, 12:53 PM
Bikeguy Joe's Avatar
I wouldn't recommend it.
Old 10-02-2009, 01:21 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Don't mess with the float!!!
Old 10-02-2009, 01:33 PM
the float is what makes fuel availible to the jet, the vacumn of the engine causes fuel to flow up the jet to mix with air flowing thru the carb as long as there is enough fuel in the float bowl yer ok, by making the jet smaller you restict the amount of fuel- leaner, enlarge the jet, more fuel-richer.frank
Old 10-02-2009, 02:30 PM
BarelyAWake's Avatar
aww... I already did
Old 10-02-2009, 11:12 PM
GearNut's Avatar
I had absolutely no choice but to adjust the float level in my carb it was set stupid high from the factory. Almost like some assembly person just put the pieces together and never checked for any proper setting. Quality control? Hahahah! yeah right! I do not think that there really is much at all when these are assembled.
YouTube - Beware of cheap engines - PK50 & PK80 assembly process
YouTube - ENGINE TESTING??? www.enginekitparts.com
Old 10-02-2009, 11:17 PM
Kevlarr's Avatar
Those are Grubee propaganda videos!
  #9 (permalink)
Old 10-03-2009, 05:33 PM
Norman's Avatar
LORD VADER Moderator
the boys on those video's ought to be able to fix your problem!!! at least one got his engine to run and it wasn't even on a bike!! Good way to set the seal in place or what ever he was doing??? Might need a bigger hammer on those leaky seals or a little tight wood ruff key on the crank. I'd like to see more videos of that high quality work, looks like they are having fun.
norms-iron-works.tripod.com
  #10 (permalink)
Old 10-03-2009, 06:38 PM
Here ya go;
YouTube - skyhawk factory work shop
