carb problem
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. put a new carb on my ch80 it will run but when i let off on the gas the motor ...
Old 10-05-2008, 09:16 PM
Motorized Bicycle Apprentice
Cool carb problem
put a new carb on my ch80 it will run but when i let off on the gas the motor dies tryed the idol screw with no luck have the crab set on the second notch which is what we are suppose to run them here in thunder bay any help would be great thanks
Old 10-05-2008, 11:50 PM
deacon's Avatar
Default Re: carb problem
Check for air leaks they are the most often stated carb problem here.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
Old 10-06-2008, 09:34 AM
Bikeguy Joe's Avatar
MODERATOR
Also, sometimes the idle screw just won't turn the idle up enough, in which case you can use the adjuster at the top of the carb. Unscrew it just until you get a satifactory idle.
Old 10-06-2008, 09:35 AM
MODERATOR
Then, re-lock the locking nut.
Old 10-11-2008, 11:41 PM
jburr36's Avatar
The last time this same problem happened to me the brass tube that the jet is screwed onto in the middle of the donut float vibrated loose. When I removed the carb bowl that brass tube fell out. Screwed it back in and all was well.
Old 10-12-2008, 12:07 AM
Saddletramp1200's Avatar
Wild guess, I saw a Honda Sabre v 45 with that problem. Take the idle needle out, and look for debris from cutting the threads for the screw. A tiny piece of metal is all it takes.
No matter where you go, or what you do, there Ya' are!
Old 10-12-2008, 11:23 AM
thanks to everyone it turn out to be a air leak on the main screw that holds the carb on never tighten up enough so thank for everyones help
Old 10-12-2008, 04:30 PM
A single ant can not move a leaf, but a hundred can! This forum is all about helping each other. It is my honor to help some one else if I can. Every one here feels the same way.
Now go riding and tell us about it Ride safe
Advertisers
