carb Idle screw..help
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. hey i lost the crb idle screw and know i can buy a new one but i dont want to ...
Old 04-09-2009, 08:51 PM
Default carb Idle screw..help
hey i lost the crb idle screw and know i can buy a new one but i dont want to wat for shipping and all that so i was wondering if any knew the size of the screw so i can try to use that and put a pen spring on it.
any other ways we be helpful too.
Thanks, Mike
Old 04-10-2009, 02:28 AM
Default Re: carb Idle screw..help
thats dax has them
Old 04-10-2009, 07:05 AM
commander's Avatar
Its a simple metric threaded screw , I know a 10 mm wrench fits the head if it were a regular bolt. But try a few metric sized bolts till you get one to thread into the carb.
Once you have found the correct threaded bolt, just simple grind the head to a cone shape , add a small spring to it and you have yourself a new ideler screw.
If you tend to loose your idle screw alot, then use a short cable lead from your fishing tackle box and wrap it around your idle screw so it stay in place, then find a nut or bolt some where to locate the other end , so that if it works its way loose again it will still be tied to the engine by the cable you just added and then you can simple reattach it .
For when it is to rainy and cold outside to play with my bike .
I go here
Old 04-10-2009, 09:28 AM
thanks guys
Old 04-10-2009, 10:25 AM
Norman's Avatar
LORD VADER Moderator
idle screw size anyway here is what I found.
thread size .7mm
length not counting the head of the screw is 11/16" long
the end of the screw is not threaded for about 3/16" and there is a about a 45 degree angle on the end.
spring is about 3/8" long uncompressed and the inside dia. about 3/16"
you should be able to get the parts at a hardware store or nappa auto parts store.
Norman
this picture might help
norms-iron-works.tripod.com
Old 04-10-2009, 11:08 AM
commander's Avatar
Norm, you are so much better at explaining what i mean to say . LOL
I go here
Old 04-10-2009, 11:53 AM
are you able run the bike with out the screw ...just temporarily
Old 04-10-2009, 12:45 PM
No way mon
  #9 (permalink)
Old 04-10-2009, 12:46 PM
ok so thats out of the picture i guess
  #10 (permalink)
Old 04-10-2009, 02:25 PM
Norman's Avatar
I added a picture of the screw.
