| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | Blew exhaust gasket Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I installed a thick exhaust gasket from Dax and it blew out in only a month. The bike seems to ...  |
04-09-2009, 10:45 AM
| | Motorized Bicycle Newbie | | Join Date: Nov 2008 Location: pittsburgh
| | Blew exhaust gasket I installed a thick exhaust gasket from Dax and it blew out in only a month. The bike seems to be a lot quicker, though, with all that exhaust bypassing the muffler. Any problem just using some gasket maker in a tube? |
04-09-2009, 12:35 PM
| | Re: Blew exhaust gasket You'll want something that will withstand 1000 degrees F.
Several layers of aluminum foil will work in a pinch.
04-09-2009, 04:48 PM
| | Re: Blew exhaust gasket Use a old school VolksWagen heat riser gasket! |
04-09-2009, 06:35 PM
|  | Motorized Bicycle Elite Member | | Join Date: Apr 2008 Location: Albuquerque
| | Re: Blew exhaust gasket Way cool I've used the foil in a pinch. What does the heat riser look like I mean does it have a matching bolt pattern . That would be the bomb then
One can do anything you set there mind to.... Do a good thing...
04-09-2009, 06:59 PM
| | Motorized Bicycle Member | | Join Date: Jul 2008
| | Re: Blew exhaust gasket Quote:
Originally Posted by VENICE BOY Use a old school VolksWagen heat riser gasket! | I was wondering if those would work. I have a few kicking around. Thanks for clearing that up for me!!. |
04-09-2009, 07:05 PM
| | Re: Blew exhaust gasket Yahoo! Image Detail for http://www.csp-shop.de/shop/images/artikel/13196.jpg
Usually there are a pair of these in a muffler replacement kit but (clamps, gaskets and hardware) Anyone who has a dual carbs on their old aircooled VW probably wouldn't need them. So there are usually plenty of these around in an aircooled VW shop. I am sure I have several. Good quality too. |
04-09-2009, 07:25 PM
|  | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Pensacola,FL
| | Re: Blew exhaust gasket Check out these copper ones, MANIC Mechanic Parts.htm ,under miscellaneous. |
04-09-2009, 09:18 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: Blew exhaust gasket im lucky my kit form gasbike.net came with 2 of everything,extra gaskets,studs,mounts,sparkplugs,caps,chain link,idle set screw,
make a gasket out of something(rubber) and use gasket maker. |
04-09-2009, 09:28 PM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Urbandale Ia
Originally Posted by Cabinfever1977 im lucky my kit form gasbike.net came with 2 of everything,extra gaskets,studs,mounts,sparkplugs,caps,chain link,idle set screw,
make a gasket out of something(rubber) and use gasket maker. | You don't mean rubber on the exhaust do you. It will never take the heat. Not for long anyway.
John |
04-10-2009, 03:41 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: Green Bay, Wisconsin (Frozen Tundra)
| | Re: Blew exhaust gasket i picked some stuff up at advanced auto for 5 bucks it came in a roll .i think its some kind of fiber. i cut up three gaskets ,put them together and have not had a problem yet.i'll try to see if i can find a link. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:06 PM. | | | Sponsors
