Bike wont Start.
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I went for a ride with my 80cc bike to the store to buy a few things. the bike sounded ...
Old 11-25-2009, 02:35 PM
Angry Bike wont Start.
I went for a ride with my 80cc bike to the store to buy a few things. the bike sounded just fine and was no problem on the way to the store. but when i got out from the store i jump on, and pull the clutch and start pedaling. when i got enough speed i release the cluch... nothing happens, so i thought i needed more speeded but when i try again it still wont start. when i parked it i took of the spark plug from a hot engine and i just read on this forum that i should do that. so i dont know if that is the reason. and when i released the cluch when i was going pretty fast while trying to start it, the clutch sounds like when i pull the clutc handle in it is 100% engaged but when i release it and the pin on the engine goes out it sound like it is like 50% engaged. because it is very easy to push the bike even with the clucht not engaged, but it wasnt like that before.
Old 11-25-2009, 02:37 PM
skjjoe's Avatar
Default Re: Bike wont Start.
got gas? spark?
stay thirsty my friends
Old 11-25-2009, 02:39 PM
ofcourse i got gas, but im not sure about the spark, how can i check it?
Old 11-25-2009, 02:45 PM
skjjoe's Avatar
hold the plug with the wire attached up to the head while rolling the bike along at a decent speed you should see the spark on the end of the plug
Old 11-25-2009, 02:48 PM
and if i dont see a spark the plug or the coil is broken or both?
Old 11-25-2009, 03:12 PM
i just checked, and no spark. so i just ordered a new spark plug and a new coil.
Old 11-25-2009, 05:49 PM
Bikeguy Joe's Avatar
Are you sure that the engine is turning properly? You won't have spark if it's not.
From your description, it sounds like the clutch is slipping.
Old 11-25-2009, 10:22 PM
Motor Boys's Avatar
I agree with Joe, sounds as if you stretched your cable, you should not be able to push your bike along easy with the clutch out. Take the right side panel off and give it an adjustment. Also when pulling your cap off could have loosened the wire to the coil or cap give it a twist both ends, either one of these should fix your problem.
Thanks
Great Deals, On Great Engines and Parts www.80ccmotorboys.com
  #9 (permalink)
Old 11-25-2009, 10:31 PM
A stretched cable will result in a clutch that won't dis-engage. It won't make the clutch slip.
If you suspect your clutch is slipping, remove the right side cover, and clean the clutch pads with brake cleaner.
If that doesn't help, you will need to adjust the tension of the clutch, which is not done with the flower nut behind the right cover.
  #10 (permalink)
Old 11-25-2009, 10:41 PM
Motor Boys's Avatar
Gotta say your right, it is easier to do then try to write about it, hats off to you Joe, I got my words crossed. i think you are bang on.
Give that a try.
thanks
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f34/bike-wont-start-13254.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 11-25-2009 07:04 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
