Bike Stops when Starting
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I do not know why this is happening. When I bring the bike to the right momentum to start the ...
Old 10-22-2009, 12:29 PM
Default Bike Stops when Starting
I do not know why this is happening. When I bring the bike to the right momentum to start the engine, and when I release the cluth the bike skids to a full stop and like some one had stepped on the brake. What could be wrong? Please help.
Old 10-22-2009, 12:39 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Bike Stops when Starting
Is it locking the rear wheel up in a skid?
Old 10-22-2009, 01:11 PM
flybytaco's Avatar
could be siezed or just too much dang compression.
couldnt build my bikes without PIRATE CYCLES and billet from CREATIVE!!!!! THANKS JUSTIN!!
Old 10-22-2009, 01:13 PM
yes it locked up the rear wheel and skids. It happened on 2 attempts. The first time it happened I check the engine sprocket that I thought it was the engine got stuck up. When I dis engage the clutch the sprocket is moving so it was not a case of stuck up engine. Realine all the wheels and chain again and tried it the second time and it locks up again and breaks the chain. I now suspecting the chain links as I have used the wallmart brand. Reading on other thread the wall mart brand is not appropriate to the MB chain.
Old 10-22-2009, 01:19 PM
The fact that it rolls fine until you pop the clutch, tells me that its probably not the chain or sprockets. The chain has no 'slack' in it, right?
Pull off the cover on the right side & see if there is anything obviously wrong?
Old 10-22-2009, 01:25 PM
Do this little experiment... pull out the spark plug & see if you can spin the engine around by spinning the rear wheel. (let the clutch lever out of course)
Old 10-22-2009, 01:40 PM
Yes thanks...I will do both of your advise. Pull out the right side and inspect. Then remove the spark plugs disengage the sprocket and spin the wheels. As for the chain there was no slack. Right now I am buying a new 415 chain. Thanks
Old 10-22-2009, 01:45 PM
Don't disengage the sprocket!! I want to know if there is anything wrong in the engine... so, spin the wheel to make the engine spin!
The engine should turn over very easy!
ALSO... check in the magnito cover for any possible problems.
  #9 (permalink)
Old 10-22-2009, 01:55 PM
I had this happen to me also, your sprockets have to be alligned fairly perfectly. If they aren't, and the chain isn't straight and it's not feeding onto the sprocket straight then it will pop off and the engine sprocket will not turn it and it will break.
  #10 (permalink)
Old 10-22-2009, 02:03 PM
Sorry...what I mean is disengage the clutch lever.
