| | | Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. | bike not moving Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. ok so I just got finished building my motorized bicycle, whenever I disengage the clutch and try to pedal, it'...  | |
05-07-2009, 12:44 AM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: grayson Kentucky
| | bike not moving ok so I just got finished building my motorized bicycle, whenever I disengage the clutch and try to pedal, it's impossible , it's like it's stuck or something, also when I pedal I hear air hissing out of the motor, I made sure the chain wasn't getting stuck and it's not the chain,can anyone help me? |
05-07-2009, 12:51 AM
| | Motorized Bicycle Senior Member | | Join Date: Jan 2009 Location: Perth Australia
| | Re: bike not moving Take the clutch sidecover off and tap arround the flower nut to release the seized clutch plates . The hissing is ok thats the engine breathing.
__________________  |
05-07-2009, 01:01 AM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: bike not moving adjust the clutch,or it might be stuck too.
it works better after you use it awhile. |
05-08-2009, 10:59 PM
| | Motorized Bicycle Member | | Join Date: Mar 2009 Location: middle of nowhere
| | Re: bike not moving oliva bear is correct
do it and it should work
If the world were a perfect place we could teleport.
Untill then we are under the rule of OILOPLIS
aka oil compyns. if you think this is wrong and want to break our dependince google david blume
or google knowledg publacations
fix the spelling u self |
05-09-2009, 10:15 AM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: Florida
| | Re: bike not moving I'm having the same problem - The rear tire will not move regardless of the clutch position. Do I have to take off the clutch plate cover and unscrew the small screw to fix this somehow? This is my first build, and I nearly got the engine started, but the clutch would keep seizing while in the free pedal position.  |
05-09-2009, 10:01 PM
| | Re: bike not moving Are you sure the cable is adjusted right and pulling the arm over enough? Can you disengage the clutch by pushing the lever over to the right?
05-09-2009, 10:29 PM
| | Re: bike not moving That was my first suspect and even If I push the arm all the way the bike won't move. I can take off the protective plate on the other side and have the friction plates exposed - still no action. The chain looks good too, no bunches or anything.
This issue would happen when I first began pedaling the bike after I built it. I could correct the lock-up by moving backwards and moving forward again. When I tried to pedal fast enough to start the motor it locked up permanently, and the motor never started. This problem looks pretty dire, I think I could get a new engine block from the ebay seller but It won't be easy. |
07-31-2009, 05:17 PM
| | Motorized Bicycle Newbie | | Join Date: Jul 2009 Location: Here
| | Re: bike not moving I am having the same problem I disengage the clutch and try to pedal, it's impossible , it's like it's stuck or something. ANY IDEAS????? |
08-01-2009, 01:10 AM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: Florida
| | Re: bike not moving its the actuator.i have the same problem.the actuator is a small shaft near the front sprocket with a ball at the end.mine fell out so i haveno clutch.try having someone push you while your on your bike.i just push off and it starts.itss hard the first few times.let me know if this helps
Brandon |
08-01-2009, 03:24 PM
| | Re: bike not moving why not replace the rod and bearing. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:19 AM. | | | Sponsors
