Acts like it wants to start, but doesnt...
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. I got my motor and installed it and it ran great for two and a half days. Then on my ...
Old 07-25-2008, 08:22 AM
Motorized Bicycle Apprentice
Question Acts like it wants to start, but doesnt...
days. Then on my way to work I stopped at a stop sign and the motor cut
off, which I thought was no big deal When I tried to start it back up
all it would do was sputter but never start. So I removed the spark plug
and cleaned it and regapped it. Nothing changed. I removed the
carburetor and emptied the excess fuel and made sure there was no
blockage in the lines. Still won't start. So I took off the exhaust and
cleaned it out tighten all bolts and nuts on the motor and readjusted
the clutch and it still won't start. I also disconnected the kill switch
thinking it may have shorted out but that didn't do anything either. It
acts like it wants to start but it just sputters and dies. I am
stumped.
Old 07-25-2008, 08:24 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Acts like it wants to start, but doesnt...
Air leak? Remove the manifold and make a new gasket out of gasket paper or at least coat both sides of the old gasket with some RTV silicone.
Old 07-30-2008, 02:44 PM
Norman's Avatar
LORD VADER Moderator
try a differant sparkplug run a gap of 0.017 to 0.025 make sure the conection on the wiring isn't loose or shorted out. some of the guys have found that the plug wire will be almost ready to fall out of the cdi if it is screw it back in
norms-iron-works.tripod.com
Old 08-04-2008, 07:52 PM
Okay, wanted to try everything suggested and hoped that one of them worked before I replied. I did use the RTV silicone and although I can tell there is greater compression, it did not fix my problem.
I also replaced the CDI and the spark plug, rechecked the mixture, checked all of my wires and I still have the same results. It just sputters. I did readjust the clutch and although it sputters it acts like it wants to catch but it's just not.
It says in the instruction to put a little dab of grease at the mesh gear area after adjusting the clutch. Well I packed it full of grease thinking more grease would be
better. Do you think that could be causing my problem, because it was
the next day when it stopped running. If so what can I do?
Thanks for all the suggestions, I'm trying everything.
Mike
Old 08-04-2008, 08:06 PM
fairracing31's Avatar
You do not want to use that much grease....thats why they say to use a dap. You are going to need to clean your clutch up with some brakeclean and maybe a little sandpaper.
With all that grease your clutch will not engage the motor.
Old 08-04-2008, 08:18 PM
How far do I need to go back? To the ring gear or further past the crank shaft ball bearing?
Thanks!
Old 08-04-2008, 09:49 PM
misteright1_99's Avatar
You need to remove the star nut and pull the clutch plate off so you can clean the clutch pucks, they probably got grease on them from the excess grease.......
Old 08-05-2008, 11:25 AM
Okay, the clutch is all cleaned and readjusted more perfectly than what it was the first time. Still having the same problem. Any other ideas?
  #9 (permalink)
Old 08-05-2008, 12:27 PM
jasonh's Avatar
are you getting any spark at all? pull the spark plug out and reconnect it to the wire. Lay it on top of the motor so the threads are in contact with the head. Release the clutch, pick up the back wheel and spin the tire. You should see spark.
If you don't see spark and you replaced the CDI with a known good unit, then pretty much all that's left is the plug wire and the magneto.
  #10 (permalink)
Old 08-05-2008, 03:26 PM
Also be sure to check your plug to be sure you are getting fuel. Crank the motor a little bit and pull the plug out, it should be a little wet.
Advertisers
