4 stroking at high revs
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle Trouble Shooting forum. can a air leak cause this at high revs?...
Old 05-02-2009, 12:03 AM
Question 4 stroking at high revs
Old 05-02-2009, 12:37 AM
Cabinfever1977's Avatar
Default Re: 4 stroking at high revs
i dont know,but you should check your bike for airleaks and seal them with gasket maker.
Old 05-02-2009, 12:49 AM
goat herder's Avatar
lightly spray mist carb cleaner around the engine if the idle goes different anywhere than directly at the carb thats an air leak. A better exhaust pipe is what I think makes these motors go better. Along with port matching. Check your plug Its needs to be a chocolate brown or slightly golden . I go for the darker side don not like suprizes. If you are just running a new engine meaning not broke in go 16 to one for break in then 20-24 to one after it takes about 3 to 4 tanks burned before break in You will feel a slite bit more power after break-in.
One can do anything you set there mind to.... Do a good thing...
Old 05-02-2009, 11:17 AM
Bikeguy Joe's Avatar
Four stroking is caused by an overly rich mixture. Move your needle clip up a notch and it should be better. You could also have too large of a jet.
Old 05-02-2009, 11:39 AM
NEAT TIMES's Avatar
Good Morning Joe. That Is What I Think Also. When Adjusting Chain Saws, I Run It Full Throttle And Open The High Speed Needle Till It 4 Cycles And Then Turn It In Till It Sounds Rite. That Way You Avoid A Lean Situation. Ron
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER
Old 05-02-2009, 04:54 PM
I learned the two cycle/four cycle thing from model airplanes.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f34/4-stroking-high-revs-7822.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 05-02-2009 07:02 AM
