Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Will 70cc 2 stroke fit newer Skyliner?
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. I was wondering if anybody has tried fitting a 70cc 2 stroke to the newest model Schwinn Skyliner? I have ...
Old 05-13-2008, 07:19 AM
Motorized Bicycle Apprentice
Default Will 70cc 2 stroke fit newer Skyliner?
I was wondering if anybody has tried fitting a 70cc 2 stroke to the newest model Schwinn Skyliner? I have installed motors on the earlier model but they have been discontinued.This one looks like it might be a tight fit.
Old 05-13-2008, 08:22 AM
Ilikeabikea's Avatar
Default Re: Will 70cc 2 stroke fit newer Skyliner?
It's kind of hard to tell just from a picture but I think it would fit in there ok..................
http://www.galtx.org/
http://bdconner.com
Old 05-13-2008, 04:10 PM
That is what I was wondering. Do you have an engine. I just took my engine into walmart to see what bikes it would fit.
Old 06-04-2008, 04:42 PM
Andy's Avatar
The motor will fit, but the carb will not fit in the normal way.
I am turning my carb 90 degrees to the left with a 1/2" copper plumbing elbow after I trimmed the horizontal leg off the manifold. I discovered a simple way to bore the manifold out using a Harbor Freight sanding cone. It allows you to step up the interior diameter very easily. Lots of aluminum dust, but it works. I am going to tin the copper elbow with solder to reduce the galvanic corrosion issue, use a set screw and lots of RTV. I will get some pictures this weekend of the set up.
Note that in this picture I am not using the back mount. I am in the process of sanding a half round channel into the actual frame of the motor, so the tube will have more surface area to clamp and rest on.
I have also removed the front derailer, as the motor was going to block it from going into the large gear. I am modding the grip shift so the left grip shift will control the rear derailer and I can put the throttle on the right.
Andy-
Old 06-05-2008, 07:49 AM
Andy,
I like the looks of that Skyliner and also the front suspension makes for a smoother ride.
Looking forward to seeing some pics of the finished product.
Old 06-05-2008, 10:55 PM
Banned
The new skyliner is too much of a hassle it appears for an engine install. This is why I've started using Schwinn Searcher bikes. Very easy install.
BTW, I found an old style Skyliner at a local Walmart. Its mine
Old 06-05-2008, 11:06 PM
There is not enough room on the New Skyliner. The Engine will not fit normally as it did with the other style Skyliner. The other style skyliner is now sold at K Mart under a different name. It is called the Schwinn Searcher. $149.00. It is one of the best bikes to put a motor on Period. You will not find a better bike with better features and quality for a better price. It handles like a dream, light weight so it is fast. And..It will stop on a Dime. The Front forks are decent as well. Not high end forks, but not cheapies either. Usually Suntour. For putting a motor on, it is a dream machine. Remember to put an extra spacer behind the rear motor mount spacer block. This will allow a better fit for the Chain drive. Enjoy the ride..
visit www.thatsdax.com for more !!
Old 06-05-2008, 11:12 PM
Also..It looks to me as though you removed the rear mount engine block spacer to fit the motor as far as you have. IS that right? If you have not scratched the bike or anything, see if you can take it back to Walmart. They are good with returns, and then go get the the other style Schwinn. Enjoy the ride..
  #9 (permalink)
Old 06-06-2008, 07:53 AM
Bikeguy Joe's Avatar
Yeah, as long as you have a receipt, W-Mart will take back anything for 90 days...as long as it's mostly there.
Similar Threads
DAX Titan 4 stroke ?'s DetonatorTuningSolutions Motorized Bicycle General Discussion 4 05-12-2008 08:55 AM
arnt all these 70cc bicycle motors the same bbike1 Motorized Bicycle General Discussion 34 05-06-2008 09:12 PM
mounting 70cc motor kit on bicycle with rear disk brakes? bbike1 Motorized Bicycle General Discussion 14 05-03-2008 01:49 PM
Chain size for 70cc Chinese frenchman159 Motorized Bicycle General Discussion 6 04-30-2008 04:48 PM
4 stroke airbox Mod Autocycler High Performance Bicycle Engine Tips 5 04-16-2008 12:43 PM
