| | | Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles. | trike motor kit Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. noob here. i tried a search already. i cant find any info on a kit the helps you mount a ...  | |
08-14-2009, 10:34 AM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: NJ
| | trike motor kit noob here. i tried a search already. i cant find any info on a kit the helps you mount a motor in the back of a trike. does one exist. something like a plate that bolts up to the holes in the trike frame kit.
kind of an advanced project for a first build but heck winter is coming. |
08-14-2009, 01:30 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Fountain Hills, Arizona
| | Re: trike motor kit
08-14-2009, 03:10 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Oregon
| | Re: trike motor kit Just build a mount for a china girl, it can't be any harder than what your already trying to do right?!? |
08-14-2009, 04:00 PM
| | Re: trike motor kit thanks guys. spooky is the closest to what i want so maybe they can help me get it done.
a plate that can mount the motor with a slot for the chain so it can be run vertically. the wheels are turning. |
08-16-2009, 04:22 AM
| | Motorized Bicycle Newbie | | Join Date: Aug 2009 Location: Fountain valley ca
| | Re: trike motor kit I'm interested too. |
08-16-2009, 08:38 AM
| | Re: trike motor kit spooky said no dice. since i have never built one i have no idea why. if you built two mounts off the frame to mount the motor why cant you run the chain vertically.
i only want to mount it there because the one i am reproducing had it there. here is a pic of the bike and what i have to start with. the royal scot i have to start with looks like a good frame to mount a motor. it also looks to be able to handle a trike rear end.
since its my first any comments or suggestions would be helpful.
08-16-2009, 11:55 AM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: trike motor kit The Trike With The White Walls Looks Like It Is Worth More Than My Car. Lol. Not What You Are Planning But I Will Take And Post A Pic Of My Friction Drive Trike. It Was Very Easy And Simple. I Think A Titan Friction Drive Would Be About As Trouble Free As Any BUILD. Ron .
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER |
08-16-2009, 03:19 PM
| | Re: trike motor kit titan friction drive, by titan? friction drive might be a cool addition to this build. |
08-16-2009, 06:59 PM
| | Re: trike motor kit I Meant A Standard Friction Drive With The Titan 4 Stroke Motor. I Have A Titan On My Cvt Dual Suspension Bike Now. I Took Pics This Morning, Will Post Pics Tonite. Ron
PUMP YOUR BRAKES
08-16-2009, 09:24 PM
| | Re: trike motor kit if you could rig a low, rack-type mount in the back, I don't see why Spooky's set-up wont work
I have built a trike using his whole arraingment...it should work
the trike rear will extend the back (bolts to orig drop-outs), so, a mount up tight to your seat-stays will work
as an example...check out how George from tuscon's trike is mounted
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:00 PM. | | | Sponsors
