| | | Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles. | Starting the motor Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. I am looking at an 80cc motor here and I am wondering how these engines are started
it says you ...  | |
03-08-2009, 04:04 PM
| | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: Minnesota
| | Starting the motor I am looking at an 80cc motor here and I am wondering how these engines are started
it says you can do pedal starts and so on
I was thinking of removing the pedals all together here
are they pull start or is there an ignition key? I am completely noobish at this but I appreciate any and all help. thanks |
03-08-2009, 04:39 PM
| | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Ontario
| | Re: Starting the motor You need to peddle to start but there is a pull start available for around ten bucks or so.
You also need to peddle the bike to get going with these kits unless you get a jackshaft kit from sickbikeparts. It allows you to use your rear gears but you need to keep your crank in place. I just tried this morning and I can start off in first gear without helping the bike to start off.
Why do you want to remove the peddles? |
03-09-2009, 01:45 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: Starting the motor the only time i hated my pedal start is when something was wrong with the engine. usually it was a clogged fuel line or out of gas but still it is a pain. |
03-09-2009, 06:38 PM
| | Re: Starting the motor Check your local laws pertaining to motor assisted bicycles. If you remove the pedals, bad idea, then your bike will not legally or technically be a bicycle anymore. It could fall under the heading of a motorcycle. In additon to the laws, having the option of pedaling can be a blessing in the event you have mechanical/engine problems far from home. Most will agree here; Keep the pedals.
Over Youth and Skill |
03-18-2009, 03:25 PM
| | Re: Starting the motor I am going to keep the pedals, i bought this 80cc kit on ebay and I am wondering how a pedal start works, do you pedal then hit the yellow throttle switch to fire the motor? |
03-18-2009, 05:16 PM
| | Re: Starting the motor Toytime,
That is a great site. It should be required reading for every new member and even the old timers might pick up a thing or two they've forgotten over the years. It should be posted here someplace that is apparent and easily located by folks just getting started or are contemplating getting into this hobby. I copied it to 'My Favorites' for quick reference. Thanks for posting it.
03-19-2009, 07:14 PM
| | Re: Starting the motor exactly what I needed, thank you a lot  one more thing....
when I look at the small sprocket that comes right off the engine, you can't turn it by hand, it is like it is in gear or something... do you just need to hook the chain up and pedal it? That is the only thing I am really unclear on, I appreciate the help |
03-20-2009, 06:45 AM
|  | UK Dealer | | Join Date: Jun 2008
| | Re: Starting the motor Quote:
Originally Posted by 2door Toytime,
That is a great site. It should be required reading for every new member and even the old timers might pick up a thing or two they've forgotten over the years. It should be posted here someplace that is apparent and easily located by folks just getting started or are contemplating getting into this hobby. I copied it to 'My Favorites' for quick reference. Thanks for posting it. | Thats why its posted in "recommended reading" Recommended Reading check it out for more essential info. Hopefully an admin will make it a sticky.
__________________ For EU and UK Kits/Parts/Fully fitted bikes.
Visit us at www.TigerToothBikes.com -
'Engines Ignited By the Finest Cigar'
"Tigertooth built him a jet
When his parts come in he'll be set
The pulse was so cool
It'd make a guy drool
He'll put one on a bike now I bet....................." - Ilikeabikea
03-20-2009, 11:11 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: Phoenix, AZ
Originally Posted by Midwest Autowerks exactly what I needed, thank you a lot  one more thing....
when I look at the small sprocket that comes right off the engine, you can't turn it by hand, it is like it is in gear or something... do you just need to hook the chain up and pedal it? That is the only thing I am really unclear on, I appreciate the help | When you are looking at it you have the clutch cover off so the clutch is engaged. You could use the included spark plug wrench to turn it, but by hand you just aren't strong enough. BTW that is a good way to feed the drive chain onto the sprocket, with that spark plug wrench.
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike. If trailer parks didn't exist would tornadoes exist? | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:01 AM. | | | Sponsors
