Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Simple bike question.
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. Is there any reason I cant have the three speed hub, put into a wide twenty inch wheel....
Old 03-12-2008, 10:56 AM
deacon's Avatar
Default Simple bike question.
Old 03-12-2008, 12:43 PM
Autocycler's Avatar
Default Re: Simple bike question.
Make sure the rim and hub use the same number of spokes. If they match, a bike shop should have no problem lacing them up
Any intelligent fool can make things bigger and more complex... It takes a touch of genius - and a lot of courage to move in the opposite direction.
- Albert Einstein
Old 03-12-2008, 01:42 PM
deacon's Avatar
Very good thank you. I have a rim that is a front wheel from a childs cruiser I'll just count the spokes.
Old 03-13-2008, 08:10 AM
deacon's Avatar
Simple question two:
Does anyone know how to take the bar out of a welded on kickstand. I cut the last one with a hacksaw and I'm NOT looking forward to that again. I need to take about an inch off it. I can also hacksaw that off but I sure don't want to do that. Those kicker bars are really touch on these old bikes.
Old 03-13-2008, 08:41 AM
Ilikeabikea's Avatar
Deacon, do you have a Dremmel tool. They make the little cutting blades for them that work pretty good. Much easier than a hacksaw. I use mine for working on bikes and airplanes. The fiber reinforced blades are much better than the non fiber reinforced...............................
http://www.galtx.org/
http://bdconner.com
Old 03-13-2008, 05:38 PM
deacon's Avatar
I use a cutoff on a drill if i really need to. I don't usually put one together just for something this small. What I did was to put a piece of pipe on the end of the kicker and bend it out. Looks like dog do but it works.
Old 03-17-2008, 03:20 PM
When you say welded on kickstand, if you mean a Schwinn Kickstand, there is a special tool made for removing these stands. If you turn the bike upside down and look at the bottom of the tube that holds the stand you will see a hole with a pin in it. What you have to accomplish is to put inward pressure on the bushing to take the load off the pin, then pull the pin with a pair of pliers. The shop in your area that used to be a Schwinn dealer will have the proper tool. Or go to the oldest bike shop in town they probably have one as well.
ocscully
Old 03-18-2008, 03:33 PM
deacon's Avatar
Thanks for the info. I just bent that one out but I will see what is what and go to the bike shop if I don't figure it out. I should have thought of the bike shop except they really hate me there lol.
  #9 (permalink)
Old 03-18-2008, 03:37 PM
Deacon, why do they hate you? All you want to do is give a bum a bike.
http://bdconner.com
  #10 (permalink)
Old 05-18-2008, 01:56 PM
deacon's Avatar
Now I have a problem that has some more simple solution than I know. I picked up a kids 16" bike for the front wheel. As a bonus I got two brake levers cables are toast. I did use one of the brake mechanisms on a bike but it needs new pads. None of that is the problem....
I really do like the handlebars. Very cool looking to me but they are that mongoose trail bike configuration. I need to take the goose neck or whatever it is called out to switch them. Can't just slide them into the one on the bike.
Now if I recall correctly and I think I do. When I start cranking the tension off the bolt, there is a sorta round sorta wedge shaped rod at the bottom of the bolt. At some point I can remove the goosie without that wedge thingie coming loose or do I have to crank it till it comes off. Sorry I just cant remember. My memory was the first thing to go alright.
Advertisers
