Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Simple bike question.
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. Deacon, just loosen the bolt up "pretty good" and give it a whack down with a board or ...
  #11 (permalink)
Old 05-18-2008, 02:36 PM
Ilikeabikea's Avatar
Default Re: Simple bike question.
Deacon, just loosen the bolt up "pretty good" and give it a whack down with a board or wooden mallet. That will push the wedge down and out of the wedged position. Then you can pull the neck out. You might have to twist it back and forth a bit if it has any rust accumulated down there. If it's stuck you might spray a little lubricant down in there and then get it started turning back and forth.......................
http://bdconner.com
  #12 (permalink)
Old 05-18-2008, 03:05 PM
deacon's Avatar
Gotcha,
I didn't remember but now I do... thanks again
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
  #13 (permalink)
Old 05-19-2008, 04:49 PM
deacon's Avatar
I got the handle bars changed out today it went just fine. Except the new bars needed a longer clutch cable. Piece of cake.. thanks Bob...
  #14 (permalink)
Old 06-04-2008, 07:27 PM
deacon's Avatar
Simple bike question 31
I hope there is a simple answer. If you know about weedeater's you know they have short throttle cables. the one I am working on has a very nice end attached to the carb already. I need to marry a long cable to go up to my handle bars.
Both cables are stranded wire but different thicknesses. I have tried a couple of simple things but nothing has been satisfactory yet. So if you have an idea please let me know. Something simple would be nice.
  #15 (permalink)
Old 06-04-2008, 08:50 PM
Do you have a hardware store that has the nico press sleeves. That would marry them together...................
http://bdconner.com
  #16 (permalink)
Old 06-05-2008, 08:04 AM
Bikeguy Joe's Avatar
...or cable clamps.
  #17 (permalink)
Old 06-05-2008, 08:06 AM
You can solder cables together with silver solder and if you do an internet search, you can find the old sailors way of tying two cable ends together.
  #18 (permalink)
Old 06-05-2008, 08:58 AM
deacon's Avatar
I got them together with nothing so fancy
I had a mending strip laying around. It is a flat piece of metal with a hole drilled in each end. About an inch long. I ran one cable through each of the holes. Then put a bolt washer lock washer and nut on each. Each cable is clamped in two places plus had the extra drag of the bar as well. If it where a brake I wouldn't even bother but a throttle has almost no real pressure. It worked great today. Thanks for the info though.
  #19 (permalink)
Old 06-05-2008, 02:55 PM
That'll work too.
  #20 (permalink)
Old 06-12-2008, 01:05 AM
bicycle parts are easier than clams on a good alaskan beach. here in seattle a group gathered 10,000 in a week to send into africa. i live in a small town 35mi. outside seattle and i can see hundreds of bicycles that never move. north bend has been yuppified, the local bike shop is full of bikes from 1-8 thousand. seattle police send thousands of bikes to the crusher a year. thats america
Similar Threads
simple yes or no answer please deacon Bicycle Engine Kits 21 01-19-2008 02:23 PM
please read these simple rules paul Welcome to the World of Motorized Bicycles 0 12-23-2007 08:29 PM
