Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Shifter/Brake Cables on Top Tube
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. The bike that I'm considering using has the control cables for both derailers and the rear brakes running on ...
Old 08-26-2008, 06:58 AM
Motorized Bicycle Apprentice
Default Shifter/Brake Cables on Top Tube
The bike that I'm considering using has the control cables for both derailers and the rear brakes running on top of the top tube. They're also open with "no cover".
I'm thinking I'll have to relocate these to mount the gas tank. Do you all know if it might be possible to mount the tank without doing this? It would sure save a lot of trouble.
Thanks!
Old 08-26-2008, 07:17 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Shifter/Brake Cables on Top Tube
There is usually little problem with those type of cables.
Old 08-26-2008, 07:20 AM
OK...thanks! I'm still waiting on my kit, so I haven't had a close look at the mounts. I've been trying to rely on pictures I can find to see if I'll have any problem areas.
Old 08-26-2008, 07:35 AM
MODERATOR
It depends on the bike really. I have looked at everything I have here, and none would interfere.
Old 08-26-2008, 09:29 AM
fairracing31's Avatar
I found this pic where someone used epoxy to keep the tank off the cables.
Old 08-26-2008, 01:14 PM
MB Donation Member
Maybe A Piece Of Conduit Or Something, Split Length Wise And Welded, Screwed Or Pop Riveted ?? Just A Thought.
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER
Old 08-26-2008, 06:00 PM
Saddletramp1200's Avatar
Na, Take an old cable and remove the case and cut to size, slide it onto the cable you want to protect. Bingo. Wally World sells cables for a few bucks. 6-7
No matter where you go, or what you do, there Ya' are!
Old 08-26-2008, 06:15 PM
MB Donation Member
Tramp- That Sounds Too Easy!!
PUMP YOUR BRAKES
  #9 (permalink)
Old 08-26-2008, 06:31 PM
Oddly enough I was at Walmart this afternoon and did just that! I taped the ends so it doesn't come off for now. A small section of rubber hose on top of that should help distribute the force. That should keep it from binding.
I have no idea why they used open cables in that area.
  #10 (permalink)
Old 08-26-2008, 10:19 PM
Ah but it's easy as pie. The cable end is the key. If it is unraveled it is impossible to do. If in good shape but slightly kinked Gently nurse it back to round with regular pliers. When I put a new cable on I use flux and lead to hold the end before i cut it. Propane torch works best. Cut it and file to taste!
Advertisers
