Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
My First Motorized Bicycle.
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. Originally Posted by grandpa2390 How do i remove the grips from my handlebars If you use a screwdriver to pry ...
  #21 (permalink)
Old 08-01-2008, 09:16 PM
fairracing31's Avatar
Default Re: My First Motorized Bicycle.
If you use a screwdriver to pry it up enough and spray with some WD-40 that will help slide it of...twist as you pull.
I use a air nozel and compressed air to get mine off
  #22 (permalink)
Old 08-02-2008, 02:35 AM
ok, i'm not sure what the clutch is. I don't seem to have it. I have what appears to be a brake leaver but the images in the instructional pictures don't match up.
Yes that is most likely your clutch lever
  #23 (permalink)
Old 08-02-2008, 07:16 AM
filestyle1's Avatar
what I do is , take a small screw driver and insert the tip just under the grip and spray a little wd-40 , then try and move the screw driver around and in between the handle bar and grip. I 've heard also if you dont have any wd-40 around , the screw driver in between bar and grip and hit it with compressed air works too! (2) the clutch lever is more or less a brake lever , if it's a new style it may have a spring loaded button on top of it for disengaging the clutch ( it will hold your lever in torward bars). (3) can you relocate your cdi box so the wires are closer? (4) Its really important to keep the two sprockets aligned ,when you mount the rear sprocket use the rubber donuts that are supplied , use one on the inside and outside of spokes , it sandwiches the spokes for a tighter fit. and also the sprocket must be true with with the wheel as close as possible.
I'll keep rollin "FileStyle"
"I'am just a penny short of being a millionaire"
Advertisers
