| | | Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles. | My First Motorized Bicycle. Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. There ya go messin around in that photoshop. I love to build stuff on the computer first. It gives you ...  | |
07-22-2008, 12:02 PM
| | Re: My First Motorized Bicycle. There ya go messin around in that photoshop. I love to build stuff on the computer first. It gives you a good idea of what it will look like in real life. I think you'll really like that bicycle with a motor installed..........................
__________________ There are only 10 kinds of people in this world. Those that understand binary and those that don't............
Become a Forever Family, it'll change your life. http://www.galtx.org/ http://bdconner.com |
07-22-2008, 01:12 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Decatur,IL
| | Re: My First Motorized Bicycle. I never had good luck with the mechanical speedometer and finally went with a digital speedo. the mechanical one , the needle jumped around too much.
" We cannot live through a single day without making an impact on the world around us. And we all have free choice - what sort of difference do we want to make?" ~Jane Goodall~ |
07-24-2008, 12:55 PM
| | Motorized Bicycle Member | | Join Date: Jul 2008
| | Re: My First Motorized Bicycle. hmm, i don't know. The real reason i want a mechanical speedometer is not for the speedometer but for an accurate odometer. I don't trust the electronics. I am afraid it might reset when the battery gets low. And I may not have batteries. |
07-24-2008, 04:30 PM
| | Re: My First Motorized Bicycle. its always fun to know how fast your going or how fast you have gone as some digital speedo's keep a max speed! and they are , I believe more accurate! as for battery's most walmart stores have the batteries and you can get them from the electronic's dept. the battery # is on most of them cr2032. and also a lot of them you can set your odometer to what it previously was , so losing any info you can always reset it.
07-24-2008, 05:45 PM
| | Re: My First Motorized Bicycle. On the digital speedometer you get codes for the wheel size...it's pretty close.
But if you measure your tire and multiply the diameter in millimeters by 3.1416 to determine wheel factor and then enter that number it will be more accurate. |
07-27-2008, 05:08 PM
| | Re: My First Motorized Bicycle. ok, Well it's almost here. MY bicycle comes tuesday, and my motor wednesday. That gives me a chance to get a feel for my bicycle before putting a motor on it. I should go ahead and order lights and an odometer/speedometer. |
08-01-2008, 03:13 PM
| | Re: My First Motorized Bicycle. So far I have mounted the motor and fixed the rear sprocket. I have completed the drivechain (or is it drivetrain) i have gotten the motor's chain on the bike and what took today's four hours was figuring out how to put the bicycle chain back on. (it is a multispeed). I am working on the cdi and clutch. But the wires that attach from the cdi to the wires on the motor were to short to reach from the top of the frame. I am concerned about the piece that mounts near the sprocket that the chain runs on. the wheel on it is loose and moves around, and (unless i managed to position it so that it doesn't do this) every now and then it causes the chain to pop off of the sprocket. I'm going to try and ride my bike without the motor today to test the sprocket chain. I must know however is it alright to move the bike around and pedal it without the clutch on it or the sparkplug in it. |
08-01-2008, 03:47 PM
| | Re: My First Motorized Bicycle. Quote:
Originally Posted by grandpa2390 So far I have mounted the motor and fixed the rear sprocket. I have completed the drivechain (or is it drivetrain) i have gotten the motor's chain on the bike and what took today's four hours was figuring out how to put the bicycle chain back on. (it is a multispeed). I am working on the cdi and clutch. But the wires that attach from the cdi to the wires on the motor were to short to reach from the top of the frame. I am concerned about the piece that mounts near the sprocket that the chain runs on. the wheel on it is loose and moves around, and (unless i managed to position it so that it doesn't do this) every now and then it causes the chain to pop off of the sprocket. I'm going to try and ride my bike without the motor today to test the sprocket chain. I must know however is it alright to move the bike around and pedal it without the clutch on it or the sparkplug in it. | Not really a good ideal grandpa to pedal around turning the motor...without it running the motor will not get any lube.
Are you sure your rear sprocket and front (Motor) sprocket are lined up together. The tensioner roller will have a little play in it. Sometimes flipping the rear sprocket over will help align the sprockets.
You also want between 1/2-3/4 inch of slack in your chain.... Replace/Repair/Adjust Chain |
08-01-2008, 03:49 PM
| | Re: My First Motorized Bicycle. ok, i'm not sure what the clutch is. I don't seem to have it. I have what appears to be a brake leaver but the images in the instructional pictures don't match up. |
08-01-2008, 03:54 PM
| | Re: My First Motorized Bicycle. How do i remove the grips from my handlebars | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:04 PM. | | | Sponsors
