Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Multi speed or single?
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. For me I want multigears, barring a flat tire that 1st 2nd and 3rd gear on a 21 speed sure ...
  #11 (permalink)
Old 10-15-2009, 08:07 PM
Default Re: Multi speed or single?
For me I want multigears, barring a flat tire that 1st 2nd and 3rd gear on a 21 speed sure comes in handy when you need to pedal to a gas station or home.
  #12 (permalink)
Old 10-23-2009, 06:35 AM
rkorson4209's Avatar
Originally Posted by BarelyAWake View Post
It's funny bairdco - I got into motorcycles when I was about thirteen, so I pretty much didn't ride bicycles at all after that. What little riding I did do was ofc multispeeds with hand brakes.
Because of that coaster brakes freak me out a little heh. Obv I've been doing a LOT more bicycle riding of late (for some reason), but my bike is multi. My friend let me take his (pedal only) bike out the other day and it was a coaster setup...
Wow, now that was weird o_O I'm sure I'd get used to it after a while, but I kept grabbin' ghost levers, not to mention lockin' up the wheel every time I backpedaled out of habit lol
But - it really does work well! I was quite surprised actually, I'd still want front brakes but that's easy 'nuff.
Still... I'm gonna keep my gears
won't the front brakes flip you over, or make you skid out? I took mine off so I could put the stock clutch lever in its place, and eliminate a cable.
  #13 (permalink)
Old 10-23-2009, 06:53 AM
BarelyAWake's Avatar
No! ... er, well... if you crush the front brake lever and lock the front tire you'll knife the wheel over to one side or the other and go down on yer shoulder, not "flip over the handlebars" as is the common thought (that's on slippery - the front usually stays in place and the rest of the bike swings around if you've good traction, but the effect is the same) - but as the front wheel is about 80% of the stopping power on two-wheeled vehicles I'd say it's worth it. During braking your inertia causes your center of mass to shift forward, reducing the weight on the rear wheel to the point of being useless insofar as braking traction is concerned - this is why it's so easy to skid the rear tire.
I've even had people tell me my rear tire was off the ground just a little when I brake really hard, I was screwing around at work the other day lol, checkin' to see just how quick I could stop my bike with my spiffy new "performance" brake pads. While I DO recommend learning what your "panic stop" distance really is at speed - be careful, it's sketchy heh and remember that while you won't go over the bars - you might still face a shoulder dig.
I hardly ever use my rear brakes as a result - I only use it to "balance" the braking power if I'm on a slippery surface like wet grass or sand. Mostly I only use the front brake to stop/slow with a finger on the rear brake lever - just in case. It's not just bicycles - this is the same technique I used with all my motorcycles, delivering pizza in the city, racing moto, even just normal putting about.
This is why you'll see that while many motorcycles and even most cars have disks in the front, the rears are still old fashioned drum brakes. While drums are more prone to "fade" from heat - it doesn't matter as much/happen as much in the back.
As for the conflict of levers on the handlebars - while there's the "dual pull/two in one" levers, I really prefer more control over which brake does what. My solution to this was to pull in my brake lever (mounted horizontally) and mount the clutch lever outside it at a roughly 45° angle down. This allows me to "two finger" the brake and pull the clutch simultaneously. I pulled in the other brake lever just so they'd match - I'm a slave to fashion lol
It's actually quite comfortable tho it does take some getting used to;
  #14 (permalink)
Old 10-23-2009, 07:33 AM
The reason I say that is because my motorcycle has disc brakes, and everytime i try using them it really feels sketchy, and one time I was riding my buddies suzuki gsx, and tapped the front brakes and almost lost it, lol, that was embarasing, especially right after I was like yah yah man I know what I'm doing, and then right at the end of the driveway, whoops. I took off so fast before he could run up on me and say never mind get off.
  #15 (permalink)
Old 10-23-2009, 07:43 AM
Practice (or lack thereof lol) is all that is - while the braking action may be too sensitive, you really can't have brakes that are too good lol
I don't let people ride my bike - for one thing I have my brakes adjusted way to "tight" (very little free play in the cable/lever) and if your not used to that, yeah - you'll dive for sure.
With cable brakes you can adjust their "sensitivity" by increasing or decreasing the amount of distance you need to pull the lever to engage the brake. While it doesn't actually change the stopping power (provided you still have enough to lock 'em up - locked up is locked up lol) it provides the comforting illusion of a greater range of applied power - which is fine, if yer brain thinks it's true - it must be and that's what is important right?
edit: BTW, those motorcycle brakes are designed to stop a performance bike going in excess of 100mph+ so yeah - they might be a lil overkill puttin' down the driveway lol, engine compression braking (on a 4stroke motorcycle, 2 strokes don't get any lube doing this) till you're almost stopped will help balance out the braking force.
  #16 (permalink)
Old 10-23-2009, 05:34 PM
The compression on a honda gx50 slows you down quite a bite and if your going down hill you need to disengage the roller off of the tire to enjoy any speed.
  #17 (permalink)
Old 11-17-2009, 01:04 AM
i personally am a fan of single speeds, but thats because im a bmxer, on my bike i just took all the cogs off the cassette and choose on that gave me a good easy ride and slapped her on there.
  #18 (permalink)
Old 11-18-2009, 05:04 PM
Well, just to throw a little more stuff out there - I have an electric front wheel drive that I run through a 3 speed Sturmy Archer. I have the same type of 3 speed for the pedal drive part. I love having gears for the motor - it gives me a choice of speed OR power and I like being able to pedal-assist too. There are a few companies making kits to run a motor (gas or e) through the pedal chain and rear hub - either a Sturmy Archer, Nuvinci, derailleur or single speed. Check out SickBikeParts.com or Cyclone. There are others too. I'm working on a mtb that will be an 8 speed ebike with a full suspension and the ability to pedal assist - jd
_______________________________________
In theory there is no difference between theory and practice. But in practice, there is - Yogi Berra
  #19 (permalink)
Old 11-18-2009, 05:22 PM
Hot Wheels's Avatar
Multi speed, just in case you have to do alot of peddling to get home it will be easier, plus if you ever want a jack shifter you will be good to go.one of my bikes WAS a single speed I hated it. I added caliper brakes and in the front I have a drum and caliper brake with a double hand brake, It stops great.
« common sense... | - »
