| | | Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles. | Lever Actuated Coaster Brake? Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. would it be possible to use a coaster brake as a hand brake? could a coaster brake be used on ...  | |
08-09-2008, 07:57 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: Deep in the American South
| | Lever Actuated Coaster Brake? would it be possible to use a coaster brake as a hand brake? could a coaster brake be used on the front wheel? if so what would be involved?
i'm thinking about repacking the rear hub of my bike while i'm waiting on the engine, and i started wondering if the sprocket were removed if a rear hub might not work for a sturdy front hub. then i thought about that brake in there... |
08-09-2008, 07:59 PM
| | Motorized Bicycle Newbie | | Join Date: Jul 2008 Location: Mio MI
| | Re: Lever Actuated Coaster Brake? WOW, did that ever get some gears turnin in my head!! |
08-09-2008, 08:01 PM
|  | minor bike philosopher | | Join Date: Jan 2008 Location: north carolina
| | Re: Lever Actuated Coaster Brake? wouldn't you have to leave the sprocket on the wheel and use the lever to pull it backwards and lock it down. Isnt that what happens when you back pedal. |
08-09-2008, 08:08 PM
| | Re: Lever Actuated Coaster Brake? Try to follow my thinking....may be hard for some:
drill a small hole in the sprocket and fasten a screw to hold the chain.........
attach a small length of chain in a fashion that could be hooked to a cable...
spring load the reverse side so as to release the brake...........
I think the rest can be figured out |
08-09-2008, 08:09 PM
| | Re: Lever Actuated Coaster Brake? Sometimes I have a hard time following my own thinking  |
08-09-2008, 08:21 PM
| | Re: Lever Actuated Coaster Brake? Quote:
Originally Posted by deacon wouldn't you have to leave the sprocket on the wheel and use the lever to pull it backwards and lock it down. Isnt that what happens when you back pedal. | i don't really know what happens inside the hub, so i was wondering if a little arm with a return spring or something might replace the cog altogether? |
08-09-2008, 08:23 PM
Originally Posted by gadgetman80 WOW, did that ever get some gears turnin in my head!! | yeah, me too! but it's probably such a good idea that there's simple a reason why it wouldn't work  |
08-09-2008, 08:26 PM
| | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Northglenn,Colorado
| | Re: Lever Actuated Coaster Brake? Mount the coaster to the forks. Get a bike chain,wrap it around the sprocket to a free sprocket welded to your handlebar. Alignment is critical so you need to strengthen your gooseneck so your handlebar won't loosen left or right. Weld a (you all seen this before) "safety lever" used in old school ten speeds with the curled handlebars that connect to your brakes so you can activate it from the top of the handlebar. Weld it to the free sprocket so it sits above your handlebar. To activate,push it down.
Man,this may be an answer to all them Schwinn chopper bikes with no provisions for brakes up front.
For the Schwinn chopper bikes maybe just a simple foot control directly off the sprocket.
__________________ You have found the fountain of youth. Ride and forever stay young. |
08-10-2008, 08:15 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2008 Location: Oswego, NY
| | Re: Lever Actuated Coaster Brake? I once considered replacing the bendix arm with a brake disc and welding a gear onto the spoke hub so that I could convert the friction hub to a clutch. The original gear would be chain driven backwards from the motor and the disc free to rotate until I wanted the hub to turn. By applying the brake to stop the now rotating bendix arm (brake disc) it will stop and the hub will go. |
08-10-2008, 08:47 PM
Originally Posted by UncleKudzu i don't really know what happens inside the hub, so i was wondering if a little arm with a return spring or something might replace the cog altogether? | Inside the hub are two wedges. When the gear rotates backwards, it forces the wedge shaped halves lock into a stationery cone (attached to the brake arm which is clamped to the frame) and forces them apart. They then pry out against the cylinder inside the hub and slow it down. The metal appears to be graphite impregnated so it will not squeal and will absorb some heat, and not be metal on metal. At least thats how I remember the one I took apart 30 years ago. Wish I could remember my gf's birthday!  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | | |
