Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Interchangability?
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. how much stuff on commonly available bicycles is standardized in regard to swapping parts from one bike to another? the ...
Old 06-26-2008, 10:01 PM
UncleKudzu's Avatar
Question Interchangability?
the cantilevered front brakes from the old DB Apex have migrated to the Goodwill Jaguar with no problem, as have the stem, handlebars and seat. but what about stuff like forks and cranks?
Old 06-27-2008, 07:46 AM
Bikeguy Joe's Avatar
Genius Visionary
Default Re: Interchangability?
I believe there are a couple sizes of cranks as well as forks/bearings.....beyond that, I am unqualified to answer.
Old 07-06-2008, 09:23 PM
nogoodnic's Avatar
I'm not familiar with the Apex but I'm thinking it is a Mtn bike? With swapping out your forks you will need to have a 1" steer tube, most modern mountain bikes (within the last 5-10years) will have 1 1/8". If it happens to be correct the next step is the length, if it is too long it can be cut down to propper length, too short, SOL, find a new fork. If you need a standard cruiser fork I can hook you up with a new one cheap. With the bottom bracket if it has a one piece crank you should be able to swap everything over, 3 piece, no. If you have more bike questions give me a shout, I know I'm way behind in my reading but will keep an eye out for this...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 07-06-2008, 09:52 PM
UncleKudzu's Avatar
thanks, Kelly!
the fork from the MtnB is probably a 1", but the tube is quite a bit longer and i don't want to cut it.
i may take good looking crank off a 20" bike and see if it'll go on the Jag; the chinese Jag pedal arms are really poorly finished and they look heavy. i also have a layback seatpost from the 20", but it's smaller diameter, but i've seen shims for cheap if i can find out the correct sizes.
i got a great 26" parts bike the other day for $9.99; all kinds of stuff on there that i can build with.
arrrgh... i'm hooked!
Old 07-06-2008, 10:40 PM
nogoodnic's Avatar
Just about any 20" bottom bracket should work on your Jag. A springer will look and ride much better than a solid stock fork. You can find them for $40-$50 on the net if you surf around. I would personally reccomend Choppers US, great quality, great service Front Ends : Forks - Choppers U.S., LLC . Look forward to seeing your bike...Kelly
Old 07-18-2008, 01:17 PM
MotorbikeMike's Avatar
Dealer
Hello, since you were able to use the stem, the fork SHOULD work, measure the steertube height, most 1" type bikes use a 22.2 headset.
NoGoodnic is correct in saying that ALMOST all 1 piece crankets and bearing sets will interchange.
The only problem I've had with 1 pc cranksets, is that real (American) Schwinns had thier own sizes on some models only, same as they did with Wheels and tires.
The other common older type headset is the 21.1 common on lightweight bikes, mostly pre mountain bike days.
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 07-18-2008, 06:58 PM
UncleKudzu's Avatar
that's good info, Mike! much appreciated.
Advertisers
