| Sponsors
| | | | | Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles. | Installing a Sprocket on a Chopper Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. I have a Sting Ray e chopper that I want to install a GAS engine on, How would anyone go ...  | |
06-28-2008, 12:46 AM
| | Motorized Bicycle Apprentice | | Join Date: Jun 2008
| | Installing a Sprocket on a Chopper I have a Sting Ray e chopper that I want to install a GAS engine on, How would anyone go about installing a sprocket with the electric built into the rear hub?
I want to keep the Electric system and have a Hyrid bike.  |
06-28-2008, 01:10 AM
| | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: PENSACOLA, FL
| | Re: Installing a Sprocket on a Chopper Very Interesting !!
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER |
06-28-2008, 07:39 AM
| | Re: Installing a Sprocket on a Chopper Not sure I understand the question. You have an electric hub on it now. You want to put an electric hub on it and a gasoline engine kit. Or you just want to install a gasoline kit.
If it is the latter you just need to buy the special mounting kit on ebay then use the regular kit. I think.
for the other two I have no idea. |
06-28-2008, 09:47 AM
| | Re: Installing a Sprocket on a Chopper Their is a electric hub installed already and I would like to attach a sprocket to the wheel spokes or the hub itself. May not to do what I want to but need advice. It is a Schwinn StingRay Electric. I have looked at it and thought about going to the front wheel but don't want to do that. I am thinking of mounting the engine above the rear wheel and running the chain down to the sprocket. Open to any ideas.
Thanks, Jim  |
06-30-2008, 10:01 AM
|  | Master Motorized Bicycle Builder | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: Installing a Sprocket on a Chopper I think Pablo's jackshaft kit would probably work well for your situation. |
06-30-2008, 10:21 AM
| | Re: Installing a Sprocket on a Chopper I don't understand how you intend to use a jackshaft when you don't have a sproket to drive the wheel. The bike already has an electric hub motor on the rear wheel, I want to add a sproket so I can power the rear wheel when I don't run the electric motor. This way I will have a hybrid bike, 3 way peddle/ electric/ gas.
Any ideas will help. |
06-30-2008, 11:09 AM
| | Re: Installing a Sprocket on a Chopper You've got a hub motor....I assume it also has pedals with a chain going to their own sprocket on the rear?
The jackshaft uses your existing chain and sprocket setup (for the pedals) to get the power from the motor to the wheel. So if you've got pedals and you use the jackshaft kit, there is no need for a new sprocket on the rear wheel. make sense? |
06-30-2008, 10:47 PM
|  | Manufacturer/Dealer | | Join Date: Dec 2007 Location: Charlottesville, VA
| | Re: Installing a Sprocket on a Chopper Hmmmm....I'm not too familiar with the bike....do you have any pics you could post?....I take it the standard 9 Hole mount will not work because the hub is too big?
Andrew |
07-10-2008, 11:09 AM
|  | Moderator | | Join Date: Jan 2008 Location: Shelby MI
| | Re: Installing a Sprocket on a Chopper Please post pics so we can see what your dealing with. Could you relace your electric hub into the front wheel and run a standard wheel on the rear for easier mounting? Just a thought...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
07-10-2008, 08:21 PM
|  | Genius Visionary | | Join Date: Jan 2008 Location: Ashtabula county, Ohio
| | Re: Installing a Sprocket on a Chopper Quote:
Originally Posted by nogoodnic Please post pics so we can see what your dealing with. Could you relace your electric hub into the front wheel and run a standard wheel on the rear for easier mounting? Just a thought...Kelly |
That would make it a three way hybrid with two wheel drive and that's one funky but chic idea.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 08:14 PM. | | |
