Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Installing a Sprocket on a Chopper
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. Here are some photos or my chopper, as you can see the hub is too large on the rear to ...
  #11 (permalink)
Old 07-10-2008, 09:58 PM
Motorized Bicycle Apprentice
Default Re: Installing a Sprocket on a Chopper
Here are some photos or my chopper, as you can see the hub is too large on the rear to install a sproket. Still trying to come up wit someway.
  #12 (permalink)
Old 07-10-2008, 10:40 PM
fairracing31's Avatar
No, I don't see
How To Post Pictures
Toward the end of this thread the members really helped me learn how to post pic's
http://motorbicycling.com/f28/post-m...tures-916.html
To use attachment:
When posting scroll down to "Additional Options"
Click on "Manage Attachements"
A window will open up
Upload a pic from your computer by clicking "Browse" then click "Upload"
Or enter the URL and then click "upload"
If you did this, and your pic's did not come out....they are most likely over sized and you must make them smaller.
  #13 (permalink)
Old 07-10-2008, 11:32 PM
Here is a photo of the rear hub.
  #14 (permalink)
Old 07-10-2008, 11:42 PM
Are there threads that I see here?? On quads for the rear axle they have really thin axle nut's....is it possible to mount sprocket here and use some axle nut's to mount it Don't know too much about E-hub's
  #15 (permalink)
Old 07-11-2008, 06:13 AM
I don't know if that would work and I thought of that also. I guess that I need to see a breakdown and operation of that drive hub, will have to do some reasearch on it.
The hub is only 250 watt 24volt and runs about 14mph, would like to have a little more speed and range.
Jim
  #16 (permalink)
Old 07-11-2008, 09:29 AM
MB Donation Member
also could do a belt drive (large pulley on rear wheel) or friction drive (front or rear ) ??
PUMP YOUR BRAKES
NEVER BEAT ON IT, GET A BIGGER HAMMER
  #17 (permalink)
Old 07-11-2008, 02:18 PM
Great ideal Neat Times
  #18 (permalink)
Old 07-11-2008, 02:39 PM
MB Donation Member
Thumbs up Re: Installing a Sprocket on a Chopper
Fairracing I Wll Pay For The Beer If You Want To Take One Over To Poor Old Moto Man, In The Heat All Day Long !! Keep Posting The Good Web Sites, Chains, Cables Etc, Good Timing For Me . Later Ron
PUMP YOUR BRAKES
  #19 (permalink)
Old 07-11-2008, 03:42 PM
jasonh's Avatar
In all honestly I still think Pablo's kit would be the cleanest solution. Not cheap, but clean and would work well. Then you don't need to install a new sprocket on the rear wheel, it just uses your existing pedal/chain/gears setup.
Eliminating the driven sprocket
  #20 (permalink)
Old 07-12-2008, 10:14 PM
Andyinchville1's Avatar
Manufacturer/Dealer
HI,
Looks like a big hub....What material is it made of?....I wonder if some "studs" for a 9 hole mount sprocket could be welded to it then simply use washers to space out a sprocket and bolt it directly to the large hub....
Just a thought,,,,Good luck!
Andrew
Sprockets now available in 9 anodized colors!
http://www.myspace.com/kingssalesandservice
http://www.youtube.com/watch?v=-zyU8n41f2c
Advertisers
