Imagine This :
Salty Gator
Hey y'alls,
Imagine this build.....Schwinn Heavy Duty.....Lady Bug Fenders....Under Tube Tank ( painted correspondingly )....all black motor with the clutch cover,magneto cover and clutch arm cover painted yellow....visualize it ......it is quite doable....
Thanks,
Salty.shft.
Is there room between the motor and tank, height & length?
You usually need a 13 or14" seat tube for the motor. If the tank ends before the cylinder it will work otherwise better go in store with a tape measure and tank dimensions.
i've seen one of those bikes in person at the swap meet. almost bought it, but i'm not a schwinn fan.
you could probably fit a V-8 motor in it.
maybe not that extreme, but it's a big frame.
It'll work....I've done extensive research...whereas the tank in itself may not clear the bottom bar it CAN be modified....but yes the engine itself will clear....I built up ( with the help of Red whom is one of our moderators ) a Schwinn Skyliner that was too dang tight for comfort but he made it work ....and so far I've almost 2500 miles on it ...I ride her hard and put her up wet....she has yet to fail me so I know the bike in question is a doable build....when the funds arise that's going to be one bad ass build....I've included a snap of the said Shwinn....so you can infer...
Thanks,
Salty.shft.
you could make a tank similar to mine, that i modeled off the original "tool box" tank from the 30's. it holds a half gallon, the same as the kit tank, and soldering up some copper is pretty easy.
Baird,
Might you have a snap of said "toolbox" tank so I can infer?
Thanks,
Salty.shft.
the first pic is what the 80 year old tank looks like, the second is the one i made, and the third is on my bike...
Sigh...I haven't the means nor expertise for such a tank...it's a work of art and I'm not a whole dollar...that's amazing and would look amazing on that Schwinn Heavy Duty....but it is possible....wow...
Thanks,
Salty.shft.
no.
i mean, i would, but without the exact dimensions and the bike in front of me, it'd be just about impossible. plus, i'd charge you a lot more than 50...;)
Did someone say, "fit a V-8 in it"?
It can be done, ya know. Just takes patients...:)
