Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Pre-Motorized Bicycle Information. Before you mount that engine to your bicycle frame, you'll want to know if the bike is ready for the engine! Ask our experts here for advice on what motorized bicycle engines perform well on what bicycles.
Any tips for mounting a 70cc on a Schwinn Jaguar?
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. I just got the bike and the engine does mount right. Any tips for the easiest way to get around ...
Old 06-30-2008, 06:58 PM
Motorized Bicycle Builder
Question Any tips for mounting a 70cc on a Schwinn Jaguar?
I just got the bike and the engine does mount right. Any tips for the easiest way to get around this? I got my kit from powerkingshop on ebay if that helps (he lists them as 80cc).
Close-up pictures of your setup would help as well.
Thanks!
Old 06-30-2008, 08:06 PM
Ilikeabikea's Avatar
Default Re: Any tips for mounting a 70cc on a Schwinn Jaguar?
I drilled through my frame for my front mount. There's a picture here somewhere, I'll see if I can find and post a link. Here's a link ...Modify the mounts or the frame..................
http://www.galtx.org/
http://bdconner.com
Old 06-30-2008, 08:38 PM
Hey thanks that is exactly what I need, where do I get the mount you used?
Old 06-30-2008, 09:29 PM
The rectangle shaped piece with 3 holes in it that is bolted to the motor, that is the piece I need.
Old 06-30-2008, 09:30 PM
I just used the flat plate that came with the engine. It slid right over the front stud bolts. I drilled a hole in the frame and put a bolt through it and then cut the little piece of tubing for a spacer...................
http://bdconner.com
Old 06-30-2008, 09:33 PM
hmm.... I seam to be missing the piece then. DAM! Anyone know where to get one?
Old 06-30-2008, 09:35 PM
Just a flat piece of metal. Drill three holes in it. One for the center bolt and two for the stud bolts. Just use like some 1/4" flat strap. Nearly anything would work...................
http://bdconner.com
Old 07-01-2008, 08:20 AM
Ok last night while I was at work (I work 3rd shift) I had the idea to take off the chain guard to give me a little more room. I just did this and the engine fits! There is a few things that may make it not work though. So, if you dont mind observing these pictures I took and tell me if it is safe to continue.
The main concern for me is the front bolts are about 3/4 threaded through the bolt. I can use something to keep the bolt on probably but do you think this will be ok? Click pic for bigger image
My second concern is the rear mount is not flush with the bar. Will this cause problems?
And last is the distance from the engine to my pedal chain. I do not think it will be a problem but what do you think?
Thanks for all the help
  #9 (permalink)
Old 07-01-2008, 09:22 AM
That looks pretty cool. You could pull those front studs out and put longer studs in. Just put two nuts on the stud and tighten them against each other. Then you can unscrew it and the whole stud will come out........................
http://bdconner.com
  #10 (permalink)
Old 07-01-2008, 05:40 PM
wow i didnt know they came out......SWEET!! Im gonna try that
You rock!
Advertisers
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
