I have some good news and bad news. The good news is I went to the gas station, put gas in, mixed oil and she fired up and ran beautifully!!
Now onto the bad news. I drove back to my place and conducted a thorough inspection to make adjustments. I then noticed the chain tensioner had move significantly and was a hair away from catching a rear spoke. So, I tried making it tighter and it still moved so I got some washers and taped them to the frame to use as shims....this kinda worked but it threw the dam thing outa wack and now because I overtightened the thing it is useless.
Oh and more bad news I tried to pop another pin out of the chain to make it a bit tighter and I broke my chain tool. What a waste of $20 that was.
So, now I need to find a better chain tool and possibly another chain tensioner.
Note to Jag owners: The chain tensioner cannot be made tight enough on our frame. You will need to find a way around this and that is what I am trying to do.
Anyone know where I can find a better chain tool? The one I got was a Park CT-5 Chain Tool so stay away from that.
Also, anyone know of an alternate chain tensioner? One that is made better and able to tighten around a smaller frame.
Edit....I found a pretty nice chain tool. You can find it here
Chain-A-Part Motorcycle chain cutter tool
