Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Pre-Motorized Bicycle Information.
Adjusted my dérailleur today....
Discussion at Motorized Bicycle Engine Kit Forum in the Pre-Motorized Bicycle Information. forum. Well I should say I started from scratch with a new twist shifter for the left side, rather than the ...
Old 05-16-2008, 08:23 PM
Pablo's Avatar
Amsoil Dealer
Default Adjusted my dérailleur today....
Well I should say I started from scratch with a new twist shifter for the left side, rather than the dangerous thumbing for gears while power riding. The twist shifter installed really easy and running the cable through was fine, but the shifting turned out to be all hosed up. Only staying in one gear, then tweaking it and only staying in high, etc.....
So I took a time out and thought about it from some stuff Jim had told me about making sure there is some, but not too much cable slack in high gear and going from there. I readjusted the cable just so. Then set the H screw, set the cable tension medium roughly, then could get it to at least go all the way to low, then set the L screw, adjusted the cable tension more precisely. Shifting was getting much better. Fine tuned the H and L screws, then dialed in the tension. Lastly I adjusted the B-tension and fined tuned again.
Here's the easy version: How To Adjust Your Rear Derailer - Bicycle Maintenance Video Tutorial
All I can say is the twist shifter is NICE!!
http://oilslubesfilters.com/
Old 05-16-2008, 08:37 PM
deacon's Avatar
Default Re: Adjusted my dérailleur today....
Sounds like me fix it first.....then do it again and again till you get it right.
visit my blog if you dare http://chinesekitmotorbike.blogspot.com/
Full novel on the blog in serial form.
Old 06-09-2008, 11:33 AM
the Goodwill Jaguar has a 7-speed twist shift, but the rear derailleur was mangled beyond repair. i'm guessing that the rear from the old MB won't work with the index shifting of the twister, so i'll probably rob the thumb shift and all from the MB for the time being.
do you do much shifting and pedaling as you ride with power? oh, and thanks for the link to derailer adjustment.
Old 06-09-2008, 12:16 PM
Pablo's Avatar
Amsoil Dealer
Yeah you are obviously best with a 6-speed twist shift if that's what MB has.
I hardly pedal, just to start it. Since I have the jackshaft kit, when I ride with power the power goes through the derailleur gears, so shifting is easy - but no full throttle shifting!!
Old 06-09-2008, 03:44 PM
Since I have the jackshaft kit, when I ride with power the power goes through the derailleur gears, so shifting is easy...
ohhh, i see. i'm still so new i didn't understand what the jackshaft was. so you've basically got a 7-speed transmission... nice! i had no idea...
Old 06-09-2008, 05:01 PM
Pablo's Avatar
Amsoil Dealer
Read here: Eliminating the driven sprocket
See more photos here: Messing with my bike....new pipe/AC/chain guard
Old 06-09-2008, 06:36 PM
wow! thanks for the link. if i'm understanding it rightly, that is very interesting.
so does this mean that a DreamBike would have a jackshaft and one of those NuVinci endlessly variable hubs :-)
yikes! expansion chambers, springer forks, dynamo drum brakes, jackshafts... what started as a simple desire for a junk commuter bike with a little Chinese engine will be an SUV when i'm done dreaming :-(
Old 06-09-2008, 07:44 PM
Pablo's Avatar
Amsoil Dealer
I Hear you!
Similar Threads
For Over 6 Weeks, No One to Ride With... UNTIL TODAY! Bean Oil Travels and Adventures 14 05-25-2008 02:34 PM
hello. i plan on buying a kit TODAY. invader-zim Introduce Yourself 17 05-18-2008 10:02 PM
Saw a motored bike today!! Pablo The Tavern 5 04-06-2008 07:48 AM
What we did at Norms today Ilikeabikea Motorized Bicycle General Discussion 12 03-03-2008 08:58 PM
Finally I was proud today Pablo The Tavern 2 02-03-2008 06:38 PM
