Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits Classic posts from all the other forums on building, repairing and modifications to your motorized bicycle engine kit.
Thought and Observations....Chain and sprockets
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. Here are a few thoughts I had, wanted to share them especially for/with the newbs. Although it isn't ...
Old 01-11-2009, 08:11 AM
Bikeguy Joe's Avatar
Default Thought and Observations....Chain and sprockets
Although it isn't crucial that the chain be in perfect alignment, it helps with smoothness, wear and the chain staying on.
Having the rear sprocket centered and mounted so it doesn't wobble side to side is also not absolutely crucial, but helps A LOT with noise, smoothness and longevity of the chain/tensioner and sprockets.
Finally, and I write this because I see a lot of it- do not over tension your chain!
Not only will it increase wear and noise AND vibration, it also causes a lot of un needed problems with the stock tensioner.
Finally, over tightening the chain will cause rapid wear to the rear wheel bearings and the countershaft sprocket bearings (clutch shaft bearings).
You may not notice it right away, but it's happening.
3/4" of freeplay is about right.
Thanks for listening,
joe
