Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits Classic posts from all the other forums on building, repairing and modifications to your motorized bicycle engine kit.
Motorized bicycle wheel balancing
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. HI All, Never really thought about wheel balance until I was looking at one of my bikes (engine free indoor ...
Old 01-21-2008, 11:34 PM
Andyinchville1's Avatar
Manufacturer/Dealer
Default Motorized bicycle wheel balancing
HI All,
Never really thought about wheel balance until I was looking at one of my bikes (engine free indoor bike) and noticed it had one of those large spoke mounted reflectors in the wheel.
Just out of curiosity I took off that reflector and weighed it....Turns out it weighed nearly 3 ounces!.....And since it was located fairly close to the rim itself I thought that was a fairly heavy wight to be so far off center.....In an attempt to partially offset some of the weight of the reflector, I did take the trouble to remount it opposite of the valve stem (every bit helps huh?)..While I have not yet personally taken the time to see how far off balance the wheel is (I will when it warms up a little since all my motorized bikes live outside in the shed Brrrr)....I was wondering if any of you out there actually too the time to balance your wheels/tires?.....In thinking about it I will probably do so
shortly because as we approach top speeds of 35+ MPH it may become important (I'll probably use stick on automotive balance weights).
What do you think?
Andrew
Old 01-22-2008, 12:12 AM
Default Re: Wheel balancing
Balancing will reduce vibration at speeds over 28mph in my experience.
However, I build my own wheels to be true to + or - .005" total run out and use quality tires with reflective stripes so no heavy reflectors are used. Balance has not been an issue. I use Slime tubes f&r and on the rear a Mr. Tuffy tire liner. My top speed is 30mph.
Mounting the reflector about halfway between rim and hub makes a real improvement. Adding another oppisite also helps. Presta valve stems are lighter than Shrader type.
Old 01-22-2008, 06:20 PM
Manufacturer/Dealer
HI Pete,
Good idea about getting another reflector to balance out the original one.....Since it is an older bike I'll have to look for a similar one or heck I may pop for 4 new ones!....Supposed to be about 40 tomorrow so I may come out of hibernation and balance all the bikes.
Andrew
Old 01-24-2008, 04:57 PM
Bikeguy Joe's Avatar
I always balance my wheels by wrapping the spokes near the rim with solder. I made a balancing table for the wheels.
Old 01-24-2008, 04:58 PM
Oh yeah, you can buy stick on lead weights at the sporting good store (used for golf clubs I guess).
