Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
motorized bicycle chain (removing and adding chain links)
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. as i said before i do not like using master links. the pictorial i am about to do will show ...
Old 02-18-2008, 02:17 PM
CRUISER's Avatar
ADMINISTRATOR
Default motorized bicycle chain (removing and adding chain links)
as i said before i do not like using master links. the pictorial i am about to do will show you how to remove and add links without the use of the master link.
only tool you will need is a link removing tool. don't buy a cheap one. get a park or even a small motorcycle one. the cheap ones can't handle the 415 chain and bend. the chain i am doing here is an old one i had laying around and a little rusty but will show you how to do it.
1. the first picture is just a picture of the tool and chain i will be demonstrating with
2. second picture is showing how you set the chain in the tool so that when you turn the lever the pin pushes the chain pin to release chain bearing cover. the trick here is you just make a very small around quarter of a turn on the tool. you just want the pin to push thru the chain link cover.
3. third picture is the chain cover being removed.
4. forth picture is pushing the bearing link thru.
5. fifth picture is the chain separated and you have a master link to put it back together
now you just repeat the process taking out as many links as you need. save the pieces as you can see is you have a master link you can throw in your bag as a spare or if you loose your master link this is a great way to make one with extra chain you may have. to put back together just do the above steps in reverse pushing pin with your tool back into the chain bearing cover. hope this helps
motorized-bicycle-chain-removing-adding-chain-100_1567.jpg  motorized-bicycle-chain-removing-adding-chain-100_1568.jpg  motorized-bicycle-chain-removing-adding-chain-100_1569.jpg  motorized-bicycle-chain-removing-adding-chain-100_1571.jpg  motorized-bicycle-chain-removing-adding-chain-100_1570.jpg
Old 02-18-2008, 03:45 PM
CRUISER's Avatar
ADMINISTRATOR
Default Re: removing and adding chain links on motorized bicycle chain
to read coments on this thread click here removing and adding chain links on motorized bicycle chain
Similar Threads
My Chain came apart!! Pablo Mounting Techniques 9 05-24-2008 02:30 AM
removing and adding chain links on motorized bicycle chain CRUISER Motorized Bicycle General Discussion 30 05-12-2008 12:20 AM
Incremental Chain Tensioning, Chain Management MotorbikeMike Mounting Techniques 12 03-04-2008 08:42 PM
All ready to go but chain bravofire84 Motorized Bicycle General Discussion 7 02-14-2008 05:54 PM
Motorized Bicycle Incremental Chain Tensioning, Chain Management MotorbikeMike Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 0 02-04-2008 12:01 AM
