Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Motorized Bicycle Carburetor install and rebuild
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. Pictures from taking the carb off the bike and taking it apart to puting it back together and some info. ...
Old 01-22-2008, 03:54 PM
Norman's Avatar
LORD VADER Moderator
Default Motorized Bicycle Carburetor install and rebuild
Pictures from taking the carb off the bike and taking it apart to puting it back together and some info. on how and what it all does well sort of and ways to change the min jet for those who want to and areas that can bite you by plugging off and sort of how to fix them. I hope this will sort out your questions if not let me know. I think this is a very nice and simple carb I think its great some of you hate it, can't make everyone happy. Here's the pictures.
The pencil is pointing to where you can turn this out and take up some of the slack on the throttle cable.
CLICK ON THUMBNAILS TO ENLARGE
Old 01-22-2008, 03:57 PM
Norman's Avatar
Default Re: Carb pictures how to
off the bike and on the bench.
Old 01-22-2008, 04:01 PM
Norman's Avatar
bang its apart. My dry board doesn't have spell check and my penmanship needs work.
Old 01-22-2008, 04:06 PM
Norman's Avatar
I wanted you to see the IDLE SCREW and the little throttle slide guide and the fuel tickler, push it down for a few seconds and it lets fuel in the carb for a cold start along with using the choke. I don't use it myself.( the tickler)
Old 01-22-2008, 04:08 PM
Norman's Avatar
this should explain its self.
Old 01-22-2008, 04:15 PM
Norman's Avatar
.026 is stock dia. of main jet on my carb to go leaner solder shut and drill smaller my suggestion is one size at a time. Most adjustment can be made with the e-clip on the needle. This mostly affects 1/3 to wide open and very little on the idle. If you can't get it tuned with the e-clip and want to go richer make sure of your stock size then drill the next size bigger then test your bike.
Old 01-22-2008, 04:18 PM
Norman's Avatar
screwdriver points to the mainjet on the very end of the emulsion tube
Old 01-22-2008, 04:25 PM
Norman's Avatar
pointing to the place where if you get trash in the tank and no filter this is where it will get to first and cause the engine to flood you got to take it apart to get it out. this can be removed by taking off the fuel line and unsrcewing the fuel inlet pipe carefully and don't loose the red gasket hard to make and will leak if you mess it up.
  #9 (permalink)
Old 01-22-2008, 04:27 PM
Norman's Avatar
explains its self
  #10 (permalink)
Old 01-22-2008, 04:33 PM
Norman's Avatar
float how it looks when its upside down I'm sure there's a measurement in china but I don't know what it is I should have measured it the pic. should get you in the ball park.
motorized-bicycle-carburetor-install-rebuild-carbpict011.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict010.jpg
Similar Threads
Carburetor pictures how to install and rebuild Norman Bicycle Engine Kits 32 06-23-2008 08:57 PM
lights for your motorized bicycle? Norman Motorized Bicycle General Discussion 21 06-01-2008 04:27 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
motorized bicycle pictures CRUISER Motorized Bicycle General Discussion 0 02-08-2008 11:39 AM
how to use motorized bicycle forum for posting CRUISER Welcome to the World of Motorized Bicycles 1 01-19-2008 04:32 PM
