Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Motorized Bicycle Carburetor install and rebuild
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. adjusting the float for the fuel level this is something to do only if you can't get it to ...
  #11 (permalink)
Old 01-22-2008, 04:40 PM
Norman's Avatar
LORD VADER Moderator
Default Re: Carb pictures how to
adjusting the float for the fuel level this is something to do only if you can't get it to stop flooding or over filling the bowl with fuel. If you ruin it you most likely will have to get a new carb. I haven't checked on parts at the cycle shops. I'm showing where to bend it I don't recommend bending the tangs as it would be hard to bet them the same and they probably are not the same anyway. messing with fuel level in the float bowl will affect rich to lean to a degree how much on this thing I don't know. lower fuel level equals learner mixture and can starve engine and you might burn a hole through the piston. something to think about. Do a plug check when messing with the carb.
  #12 (permalink)
Old 01-22-2008, 04:53 PM
Norman's Avatar
I'm not a big fan of silicone but there is a time and a place for this stuff. This will seal the intake to carb very, very, I do mean very well. YOU WILL NOT SUCK SOMETHING into your engine and cause you a big heartache this way. I ,m showing you how easy it is to do step by step.
motorized-bicycle-carburetor-install-rebuild-carbpict015.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict016.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict017.jpg
  #13 (permalink)
Old 01-22-2008, 05:04 PM
Norman's Avatar
push it together. you can do this on the bike if you got the room sometime you will have to remove the aircleaner to mount the carb on a tight fitting frame. after pushing it together just a little twisting to help spread the silicone and aline up the casting seams on the carb and the manifold tighten the bolt and TADA.( I polished off the seam fooling around with the polishing wheel and never mind the weird fitting its for a boost bottle and I wanted to try one so I made one. I would recommend a tuned pipe money better spent and thats my 2-cents but they don't hurt anything and if you want it to look cool sticker and all go for it. I did find the engine will idle at a much lower setting on the idle screw and the thing seems to run smoother but top end nada. My final thoughts on the boost bottle is don't waste your time on them.
motorized-bicycle-carburetor-install-rebuild-carbpict018.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict019.jpg
Last edited by Norman : 04-16-2008 at 09:47 PM. Reason: bogus boost bottles my 2-cents.
  #14 (permalink)
Old 01-22-2008, 05:22 PM
Norman's Avatar
as the picture says no part of a o-ring sticking out in the bore and no need to worry about it coming loose and the engine eating it. the carb should not come loose or leak and you don't have to worry about keeping the carb pushed up tight against the ring while tightening it. I rest my case.
  #15 (permalink)
Old 01-22-2008, 05:26 PM
Norman's Avatar
airbreather exploded view. I cut the opening where the air comes in on the breather teeth opened it up a little. the gain? more noise for sure.
  #16 (permalink)
Old 01-22-2008, 05:33 PM
Norman's Avatar
I thought I'd show the choke and the symbols we all know what they mean . you can read chinese can't you. The filter ain't the best but it works for me and I'm cheap. #2 pic. almost done the last parts to go in the carb and again the stock setting and parts aligned on sequence of assembly
motorized-bicycle-carburetor-install-rebuild-carbpict022.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict023.jpg
  #17 (permalink)
Old 01-22-2008, 05:41 PM
Norman's Avatar
I should delete as this didn't turn out real well. I wanted to show you how to make the cable end for the carb made out of a single strand of copper phone wire wrapped around the cable and silver soldered and there is an example of the wrapping and a finished end I made these just for this post on a scrap piece of cable ther's more ways to do this I find this very simple to do. The silver solder to me is important don't want the end to get loose and go through the engine and that is where it will go if it gets a chance. Nasty picture.
  #18 (permalink)
Old 01-22-2008, 05:47 PM
Norman's Avatar
bottom picture is a little out of focus but shows how the thing looks assembled correctly
motorized-bicycle-carburetor-install-rebuild-carbpict025.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict026.jpg
  #19 (permalink)
Old 01-22-2008, 05:54 PM
Norman's Avatar
pen pointing to an adjustment area for taking up slack on the throttle #2 pic my throttle cable has another adjustment up at the twist grip to take the skack out of the throttle cable.#3 all done. #4 its running and its cold .
Thats it hope your questions got answered if not give me a PM.
Norman
motorized-bicycle-carburetor-install-rebuild-carbpict027.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict028.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict029.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict030.jpg
  #20 (permalink)
Old 02-11-2008, 07:19 AM
CRUISER's Avatar
ADMINISTRATOR
Default Re: Motorized Bicycle Carburetor install and rebuild
original thread for coments and questions click here Carburetor pictures how to install and rebuild
http://stockmarketcats.com/
Similar Threads
Carburetor pictures how to install and rebuild Norman Bicycle Engine Kits 37 07-22-2008 11:10 PM
lights for your motorized bicycle? Norman Motorized Bicycle General Discussion 21 06-01-2008 04:27 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
motorized bicycle pictures CRUISER Motorized Bicycle General Discussion 0 02-08-2008 11:39 AM
how to use motorized bicycle forum for posting CRUISER Welcome to the World of Motorized Bicycles 1 01-19-2008 04:32 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
