Re: The clutch. 1. this inner part is the driven part of the clutch turn rear wheel and it goes around. Great just what you wanted to know.the little nub in the center is the rod that works the clutch plate and inside there somewhere is the spring that slams the silver plate shut onto the pads to make it all work and not that wossy spring we took off before even Rufus knows that.
2. turn flower nut clock wise to stop slipping and counter clock wise to make it slip but pull in and lock the lever on the handlebars so you can spin it( the flower nut) with your fingers. 1 to 2 turns may be too much keep reading and looking as its easy if you do it right. I ain't lieing well a little. Heck I'll send Rufus he will get it right and make all of us look like fools.
3. how the lever and arm should look when everything working the clutch lever arm should have a little slack when adjusted correctly 1/16" or a little free play.
4. when clutch is pulled in, how it will look again your arm position my vary a little so hang in there cause there is the easy way to turn the flower nut( pull in the clutch lever and set the lock) and you don't need a wrench like I've seen on posts else where. which I've said a doz. times, wella few times? Don't get me mad, Rufus will turn loose the flyin monkees and you know what they did to the scarecrow don't you?!! |
