Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Kick stand fix for schwinn motorized bicycle
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. Here is all you have to do is drill with a #25 drill and tap with a 10-24 tap ...
Old 02-28-2008, 07:58 PM
Norman's Avatar
LORD VADER Moderator
Default Kick stand fix for schwinn motorized bicycle
Here is all you have to do is drill with a #25 drill and tap with a 10-24 tap and insert a long 10-24 set screw with lock tite on it. The set screw will limit the amount that the kickstands leg can extend in the down position. Stock it will come all the way down and allow the bike to lean over too far and then its on its side. you can use a different size screw if you want and use a bolt or regular screw in place of the set screw.
I don't have a before picture but its stands nicely now
My finger is pointing to the screw where it sticks out on the inside of the stand and limits it travel. You can see a mark on the stands leg where the set screw has left its mark on the leg
I have an allen wrench in the set screw adjusting it to make the bike stand up better the Allen wrench is hard to see but it is there if you look closely. It looks like a black rod. the darn picture is just a little out of focus. but you get the idea.
This is an easy fix for a bike that likes to lay down all the time if your kickstand is like this one.
kick-stand-fix-schwinn-motorized-bicycle-schwinnbike.jpg  kick-stand-fix-schwinn-motorized-bicycle-schwinnbike017.jpg  kick-stand-fix-schwinn-motorized-bicycle-schwinnbike016.jpg  kick-stand-fix-schwinn-motorized-bicycle-schwinnbike015.jpg
norms-iron-works.tripod.com
Similar Threads
Kick stand fix for schwinn Norman Motorized Bicycle General Discussion 2 02-29-2008 03:17 PM
My Two-Stroked Motorized Schwinn Cruiser Bean Oil Pictures and Videos 6 02-24-2008 06:58 AM
Couldn't stand it no' mo'! Bikeguy Joe The Tavern 6 02-15-2008 06:19 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
Egors Motorized Schwinn Egor Pictures and Videos 12 02-04-2008 10:02 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
