Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Engine Kit Classic Posts > Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits
Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits Classic posts from all the other forums on building, repairing and modifications to your motorized bicycle engine kit.
4 cycling mystery solved!
Discussion at Motorized Bicycle Engine Kit Forum in the Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits forum. I have been reading a lot of posts lately about engines that four stroke a lot, some all thew time. ...
Old 09-11-2009, 11:29 AM
Bikeguy Joe's Avatar
Default 4 cycling mystery solved!
I have been reading a lot of posts lately about engines that four stroke a lot, some all thew time. I have a bike here I built a while back, and have been unable to sell it due to the fact I couldn't get it to ever break into a clean 2 cycle.
I changed the stock plug and wire, tried every setting on the needle, soldered and re-drilled the jet to the proper size, ect.ect.
If I put the "C" clip on the top notch, it would STILL 4 cycle and have very little power, if I moved it down it would get more power on each lower setting, but the 4 cycling was still there, no better, no worse.
Finally, today, I said "I guess I'll just go run this one hard and see if it's a ring sealing issue, break-in problem, ect, I'll either cure it or kill it." (I was just a bit frustrated, having run this bike for 20 miles or more and still running badly with everything I'd tried.
I was doing my "pre-flight inspection" and noticed the throttle cable was a little loose. The adjuster at the top of the carb is all the way out, so I looked at the throttle assembly. Apperently, I overlooked a shoddy fit where the cable housing goes into a sleeve and into the throttle housing. I used my aircraft cable swaging tool to squeeze the sleeve down tighter, and pulled the slack out of the cable before doing so.
THIS WHOLE TIME, THE ENGINE WAS 4 CYCLING BECAUSE THE CABLE WAS ONLY PULLING THE THROTTLE 3/4 OPEN AT BEST!!!!! I never got a good carb setting due to an overly large jet to begin with, and then the throttle not opening all the way meant I never really had a shot at setting the carb right.....
Yeah, I feel stupid being the "Godfather of motorized bicycles" and all to have let such a simple, tiny problem cause me so much grief.
I'm gonna go ride.
