| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | Zbox Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. hi my names bill and im 14 ive been looking to put an engine on my bike for ages and ...  | |
10-25-2008, 03:59 AM
| | Motorized Bicycle Newbie | | Join Date: Oct 2008 Location: Sydney
| | Zbox hi my names bill and im 14 ive been looking to put an engine on my bike for ages and i found this aussie made kit called Zbox oh and im looking for a chain drive or belt MOTORISED BICYCLE ENGINE KIT ZBOX BIKE MOTOR AUSTRALIA 48cc MOPED - AUD$235
but wanted to know with this kit can i still use my bike as a bike like having the engine engaged to drive and disengaged to pedal but will i be able to still use the gears on my mountain bike so i can go in 1st 2nd and so on also are there anytuned pipes for these as i would love to have more power
oh yeah and wat speeds may i be able to get upto on these things and im looking for something with lots of power but about in the $250-$350 price range
Thanks |
10-25-2008, 03:05 PM
| | Re: Zbox Hello Bill, Welcome to the forum glad you joined us
Yes you can still pedal your bike like a regular bike with the engine kit. But, their will be more resistance which will make pedaling a little harder.
Speed all depends on your weight and terrain and what sprocket you have. Most kits will come with a 44t sprocket that should get you around 25-30mph. You may want to look into... Welcome to Sick Bike Parts. It's a jack shaft kit for your kit that will allow you to use the gears on your bike.  |
10-25-2008, 05:09 PM
|  | Motorized Bicycle Senior Member | | Join Date: Aug 2008 Location: Coffs Harbour, Australia
| | Re: Zbox Hey I've had a zbox for a year now and there great motors, you can get a kit a bit cheaper off ebay like for as lot as 150 but they sell for about 180.
Stick with your stock sproket cauce it great for hills and for top steed and if you are in Australia is really hard to get a smaller one.
Thanks ,Brad |
10-26-2008, 02:12 AM
| | Re: Zbox Quote:
Originally Posted by 4wdingman Hey I've had a zbox for a year now and there great motors, you can get a kit a bit cheaper off ebay like for as lot as 150 but they sell for about 180.
Thanks ,Brad | will do but what do you think about the shifting kite etc is there like a ZBOX certified seller on ebay or something |
10-26-2008, 04:17 AM
| | Re: Zbox well they only sell shifter kits in the us and they are not streat legal. A bike with a motor and gears in not streat legal but a bike with a motor and one gear is streat legal. The kits that sell on ebay come from the same place as zbox motors come from but if you are a first buyer of a motorized bike kit buy from zbox becuase on ebay if something doesn't work well your stuck if something doesn't work with zbox they will help you and replace the broken part for you.
Thanks |
10-26-2008, 04:33 AM
|  | Motorized Bicycle Elite Member | | Join Date: Oct 2008 Location: Australia Brisbane
| | Re: Zbox Hey mate
Yer i got a Zbox engine. i would say probly 1 of the best 2 stroke in the aussie market.
yer iv got a stock engine stock exhause i can get to bout 50km on the flat with no wind.
Im not sure if there is a Zbox seller on ebay. probly just easier to get it from zbox.com
yer and Warren there is real helpful if anything goes wrong. |
11-09-2008, 09:16 PM
| | Motorized Bicycle Newbie | | Join Date: Nov 2008 Location: Australia
| | Re: Zbox I have bought a zbox engine, and it has taken me a while to set it up on my bike. I
am at the stage where I will soon purchase fuel and put some in the tank
to try it for the first time.
My concern is that the instructions state that you should add loctite to head bolts and torque them to 12...
Well I would have to undo the head bolts to put loctite on the studs. I
am a bit apprehensive about doing this. I have never removed the head
from a motor before. |
11-09-2008, 10:29 PM
| | Motorized Bicycle Member | | Join Date: Sep 2008
| | Re: Zbox I've got a Zbox too, I've had no trouble with it at all. Starts first time, every time. Only thing that bothers me a bit is it's a bit noisy, I'm going to look at damping rubbers between thhe fins one of these days... |
11-11-2008, 02:37 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2008 Location: Asia
| | Re: Zbox Got 2 of my Z80 engines from ZBox... I burned my first one, because the intake gasket got screwed and was not aware of it. My 2nd seems to be still running good, but had a small hole near the exhaust from cast bubbles. I just cold weld it. I cut out my own intake gasket from gasket paper and made sure it covered all area of contact and make a good seal.
You can use the shifter kit from SBP to drive your bicycle gears, tuned pipes from Andy and some other guys. There are lots of products you can find here. Also, a clutch upgrade kit.
__________________ It's more than a hobby, it's my transport. Caution: This hobby is habit forming.
Reason: add info
11-11-2008, 03:06 AM
| | Re: Zbox Quote:
Originally Posted by stephen braithwaite I have bought a zbox engine, and it has taken me a while to set it up on my bike. I
from a motor before. | For me, I did not put loctite on the studs. But I did remove the head and put a little head gasket sealant on the aluminum head gasket. I just retightened the bolts and nuts in an 'x' pattern after 1 hour engine run on the first 5 full tanks. After that, the nuts and bolts did not come loose anymore.
For a thorough disassembly intstructions: http://motorbicycling.com/f30/bicycl...-down-391.html
Reason: add info
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:52 PM. | | | Sponsors
