Originally Posted by xlite Environmentally conscious individuals will use 50:1 or synthetic 100:1. Others need to leave a trail behind so they won't get lost so use more oil.
FYI more oil in the gas results in a leaner mixture, not richer. |
I believe the OP meant richer as in "oil to gasoline".
But, yes think about it....at 32:1 you have twice as much gasoline running through the jet than you do at 16:1.
In honesty, I run 40:1 any more since all my other "goodies" run that mix.
I have recommended 24:1 in the past because I have had a couple of Big Name sellers ask me to refrain from suggesting anything but 16:1 or 20:1 for warranty reasons, so that is sort of a compromise.
So, for the record, run whatever you are comfortable running, and live with the concequences.
