why
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. is it that i have to put up my chocke then try to start my engine then put down my ...
Old 11-09-2009, 02:43 PM
Default why
is it that i have to put up my chocke then try to start my engine then put down my chocke so i can ride my bike i have never had this problem before... anyone???
Old 11-09-2009, 02:46 PM
Default Re: why
"Choke", I guess you mean?
Two things I'd check:
1) your air filter is getting dirty (will still work for a while, but engine is already not producing full power), or-
2) junk in your fuel jet.....
Old 11-09-2009, 02:50 PM
Maxvision's Avatar
Default Re: why
Didja put an inline fuel filter between your carb and gas tank?
Old 11-09-2009, 02:57 PM
Default Re: why
i lost the idle screw on the motor and i forgot to cover the whole so im guessing air got into it could that be the probelm
Old 11-09-2009, 03:00 PM
Maxvision's Avatar
Default Re: why
Hrmmm....could be...
Did the problem start right after you lost it?
That open hole could be causing your bike to run LEAN. Expect a melted piston in the near future.
Old 11-09-2009, 03:05 PM
Default Re: why
well i got a new screw for it but i dont know when the problem started because i lost it when i was still installing the motor so i started running it when i got the new screw should i just buy a new motor
Old 11-09-2009, 03:10 PM
Default Re: why
wait why did you mention the filter because i have one between the carb and the tank
bairdco's Avatar
Default Re: why
wait. so you just need the choke to start it, and then it warms up right away and you put the choke down and it's fine?
that's normal.
i start my bike with the choke up, then depending on how fast it warms up, i put it down and everything's fine. usually 10 to 20 seconds with the choke on works for me.
that's what a choke does. it's for cold starts.
  #9 (permalink)
Old 11-09-2009, 03:28 PM
Default Re: why
oh really well this is the first time out of the 8 that ive had that this has happened to me well its good to know im not the only one also saved some money buy not buying a new motor
  #10 (permalink)
Old 11-09-2009, 03:38 PM
bairdco's Avatar
Default Re: why
if it just takes a few seconds with the choke on to get it running, everything's normal.
as the weather gets colder, you'll need to use the choke more often to start it.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62
