| | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | White wire Question Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. As the white wire from the magneto on a HT engine provides some output, could it be connected to the ...  |
12-18-2008, 11:05 AM
| | Motorized Bicycle Newbie | | Join Date: Sep 2008 Location: Forest of Dean (England)
| | White wire Question As the white wire from the magneto on a HT engine provides some output, could it be connected to the blue wire to provide a stronger spark at lower rpm.
I ask this because, since fitting a pullstart, I'm finding it more difficult to start.  |
12-18-2008, 11:09 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2008 Location: Longmont, CO
| | Re: White wire Question I doubt it would work out.
If the motor is hard to start, check your plug and wire. If you're using a stock plug, that might have something to do with it. |
12-18-2008, 11:24 AM
| | Re: White wire Question Hi jasonh, I have a new NGK6HS fitted & a good lead.
I just think the speed at which I'm spinning it over by hand is not as fast as pedalling & releasing the clutch. Maybe I need to visit the gym so I can pull the rope harder!!!
Cheers. |
12-18-2008, 04:52 PM
| | Re: White wire Question Push the tickler for a second longer.
12-18-2008, 06:41 PM
| | Re: White wire Question  Thanks Bikeguy Joe, I tried giving it extra tickler & it definitely started a lot easier.
I tend to only give it a couple of pumps as the only other carbs I've had a tickler on was my old Norton's, Triumph's etc. If you gave them too much tickle the fuel would always overflow. These little carbs can take an amazing amount of tickling without splilling petrol over the rest of the engine!!! |
12-19-2008, 05:46 AM
| | Re: White wire Question A lot of it goes down the intake on these, so be careful.
You almost can't flood a two stroke when it's cold, the extra tickler seems to work great. I usually don't even use the choke anymore.
12-19-2008, 09:37 AM
| | Re: White wire Question You're right, I can see now that the fuel would run into the intake before spilling out.
I'll bear that in mind when I'm "tickling" her in future. Cheers. |
12-19-2008, 02:51 PM
| | Re: White wire Question hmm, interesting, I never thought of using the tickler to get a bit of fuel in there instead of the choke. I rarely push the tickler anyway though, so no reason to start now  | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:22 PM. | | | Sponsors
