| Sponsors
| | | | | Motorized Bicycle General Discussion Topics on bicycle engine kits, help articles, repair and modifications for your motorized bicycles | **whats Wrong With My Cluth?** Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. two days ago my idler wheel fell off and became unusable from my way home from work. so to make ...  | |
08-02-2008, 09:42 PM
| | Motorized Bicycle Builder | | Join Date: Jun 2008
| | **whats Wrong With My Cluth?** two days ago my idler wheel fell off and became unusable from my way home from work. so to make it the rest of the way home i took my chain partially off so i could ride it like normal. today i tried to reassemble the clutch plate but i am not getting any tension at all when i try to fasten the clutch cable. attached are some pictures. i don't know what happened, but when i attach the clutch plate i can push the lever counter-clockwise with no pressure at all. so basically its not engaging the clutch, any suggestions? |
08-02-2008, 09:50 PM
| | Re: **whats Wrong With My Cluth?** Got the little shaft and ball inside? |
08-02-2008, 09:52 PM
| | Re: **whats Wrong With My Cluth?** i don't know, does that come out easily? if so, it may have come out when i was riding home cause i didn't have the clutch plate on. how much does that cost to replace? |
08-02-2008, 10:32 PM
| | Re: **whats Wrong With My Cluth?** ENGINE_KIT_PARTS_PAGE_3
$4.99 - but looks like he is out. |
08-02-2008, 10:33 PM
| | Re: **whats Wrong With My Cluth?** I think Dax had the pin & ball for like five bucks but last time I saw he was out of stock. |
08-02-2008, 11:30 PM
|  | Master Motorized Bicycle Builder | | Join Date: May 2008 Location: Corpus Christi, Texas
| | Re: **whats Wrong With My Cluth?** It was a dark stormy night, deep in the back woods on the way to grandma's house, No sorry wrong forum. Where is the grease that is supposed to hold the bearing in place? You took it apart on the side of the road and it fell out.
Been there myself. Ball bearing and pin Dude, that will get you riding again
I look at my clutch at least once a month, or 6 tanks of gas. No shame, we all get lax in the thing we need to do. I am the first to admit that. No biggie!
Later Tramp
No matter where you go, or what you do, there Ya' are! |
08-03-2008, 03:29 AM
| | Re: **whats Wrong With My Cluth?** Hi Bowler.
Regarding the clutch rod and ball-bearing:
Good news and bad news (mostly good):
First of all, you may still have the ball bearing. It is usually difficult to remove (because it is almost held-in with greasy vacuum), and most people have to remove it with a magnet.
The rod is probably lost somewhere. ThatsDax is currently out of stock, however, you may make one. You may purchase a steel rod of identical diameter from Ace Hardware, and cut your own. The rod goes for about $4.00-$5.00, and is about 5 feet long.
There are two different versions for the length of the rclutch rod (per Duane from ThatsDax).
If you inspect with a flashlight, and see that the ball bearing is also gone, some Ace Stores sell ball the bearings. If your ace doesn't have it, any bicycle shop should have the right bearing.
Does anyone have the specific sizes available?
PS (Never drive bike with clutch box open. The same thing happened to me once)
Send me a personal message if you can't determine the correct sizes.
VaporKing
__________________ |
08-03-2008, 07:58 AM
| | Re: **whats Wrong With My Cluth?** 5/16"x1" is what I got.
08-03-2008, 09:14 AM
| | Re: **whats Wrong With My Cluth?** haha, yeah, thanks for all your help. i guess i wasn't thinking properly when i was trying to fix my bike. i just caused a different problem  i guess you live and you learn. |
08-03-2008, 12:36 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice Beach, CA.
| | Re: **whats Wrong With My Cluth?** You should've just taken the master link out of the chain! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 11:04 AM. | | |
