What type of chain is a chain tool used on?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Obviously a normal chain link is a better idea than a removable link. So is a chain link removal tool ...
Old 07-10-2009, 10:26 PM
Default What type of chain is a chain tool used on?
Obviously a normal chain link is a better idea than a removable link. So is a chain link removal tool for all chains or a certain type? In other words, can I use a normal link instead of a removable link. And if a tool is used to remove a link and then replace a link, isn't the pin fitting looser then it did before removal.
Thanks. Just trying to determine if I should buy a tool. That way I could use the extra links I removed instead of having to buy a new master link.
Old 07-10-2009, 10:31 PM
joewlms3's Avatar
Default Re: What type of chain is a chain tool used on?
shimano and sram make some chains that have links with pins that push in with the tool but those are for road bikes and mountain bikes and they usually cost more
Old 07-10-2009, 10:32 PM
joewlms3's Avatar
sorry the chain tool is also used to shorten the regular chains
Old 07-10-2009, 10:45 PM
you could put the chain togther without a master link, many bikes come like that... but it becomes a pain when you want to take the chain off.. just remove the other side of the link, and push a pin thru the assembled peice
Old 07-10-2009, 10:57 PM
Cabinfever1977's Avatar
chain breaker with master link $5 walmart.
Old 07-10-2009, 11:02 PM
yea, I made the mistake of buying 1 of those... the soft aluminum thread's pulled out. I did manage to push the pin out that I needed out with it, but when I finished, I noticed the chain guides had folded over from the preassure....
now when I need to break a chain, I use a dremel and a pin punch
Old 07-10-2009, 11:06 PM
my chain breaker is still working like new after 3 or 4 times. but i bought it for the master link. what do you expect for $5,buy two if you have to.
Old 07-10-2009, 11:23 PM
the 1/8"-3/32" master links it comes with, won't work with the 415 chain... as far as the chain breaker, when I get around to it, I'll get a decent 1. till then I'll continue to use a pin punch... decent chain breakers are $10 at Harbor Freight
  #9 (permalink)
Old 07-10-2009, 11:45 PM
I guess part of my question was meant to ask, but didn't do so, if I remove a pin, can the pin be put back in or will it just fall out again? Or if I remove a pin, is the only way to join the chain back together, by replacing the link with a master link with a clip? My point is, is the snap link the only way to break a chain and join it back together?
Do know why I am having so much trouble saying this. I must be tired :-)
  #10 (permalink)
Old 07-11-2009, 01:04 AM
you only push the pin out one side to get apart then put back together and wack the pin back in.
the breaker from walmart does come with a 415 master link,i bought it and is using it.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f3/what-type-chain-chain-tool-used-9512.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 07-11-2009 02:43 AM
