What kind of mountain bike for a bicycle engine?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello, I am looking at buying a used mountain bike 26" for use with a bike engine kit. Now, ...
Old 01-09-2008, 10:55 PM
Motor Bicycle Apprentice
Default What kind of mountain bike for a bicycle engine?
Hello,
I am looking at buying a used mountain bike 26" for use with a bike engine kit. Now, I have noticed some riders here have what I deem as an older/unique bike style that they mount the bike engine kit to. I really enjoy the looks of a mountain bike and wanted to know if anyone had any information to share about a mountain bike brand ex. Trek/cannondale that they felt comfortable with and enjoyed riding with a bike engine kit.
Thanks for your help
Old 01-10-2008, 07:11 AM
Bikeguy Joe's Avatar
Default Re: What kind of mountain bike for a bike engine?
I'll add the obvious....look for one with or without rear suspension that you can still fit the engine within the frame. Also, if you plan on using it for off road, you may want to look for a beefy frame (compare) and use one of the 46 or 48 tooth sprockets for more low end grunt.
These engines will haul a lot of weight so don't be overly concerned with the total weight of the bike/rider.
Old 01-10-2008, 10:20 PM
Thanks for the reply.
Yes I am tall and shall I say "average weight for my 6'6 frame. I am 250 pounds, so I like and look "normal" on a beefy mountain bike. I know that most of the beefy frames are rather large and would wonder if the engine would be able to fit and work with a larger frame. I spoke with a dealer not to long ago and he told me that some bike engines have a hard time bolting to larger diameter frames. I was unaware that a 46-48 tooth sprocket could give more low end. With my weight I would need it. Thanks for your post!
Old 01-11-2008, 06:16 AM
Mounting to the larger diameter frame tubing is pretty simple...there are several ways to do it. Some drill holes and use longer studs, some mount with an exhaust mount. You bolt that to the engine, then use a couple of heavy duty muffler or hose clamps to connect that to the frame. I'll dig that part out and get a part number for anyone intetrested in that mounting technique.
As for the sprockets, I have a couple of them if any one is interested. I don't remember if they are 46 or 48 tooth, but any one interested can PM me and I'll dig 'em out and count the teeth and we can talk price (nearly free+shipping) then.
Old 01-11-2008, 08:54 AM
CRUISER's Avatar
ADMINISTRATOR
i weigh about 210lbs and ride real hard. i have never had a problem with any frame unless i crash. i have had probably 20 mountain bikes over the years. personally for my motor bicycle i wanted a chromoly frame. they are very strong and most of your inexpensive bikes are made with it.
Old 01-11-2008, 12:46 PM
Andyinchville1's Avatar
Manufacturer/Dealer
HI,
For ease of installation I like a slightly large frame (size wise) made from with the standard size tubes.....Mountain bikes fitting this description are harder to find....seems like everything has gone to over sized tubing and/or rear suspensions that always have the shock in the place where the engine needs to mount to (assuming a center mount happy time type engine).
I have sold a few bikes locally to people and for cost / ease of availability reasons I have been using the silver Road Master mountain bike they sell at Wal Mart for about $60.....This is definitely not a high quality bike but it seems that most of the local buyers here stress low price over anything else....At least I hope until they get bitten by the mortorized bicycling bug!.
This frame is the exact opposite of easy installs (small tight fit requiring shaving of the air filter housing, denting the frame so the factory front engine studs straddle the down tube (not enough room to use the oversize tubing frame adaptor) etc....but it does
look nice and the bike is definitely priced low.
My personal bikes are Specialized Rock Hopper and a Trek 7000....Both mountain bikes.
Good Luck and have fun!
Andrew
Old 01-20-2008, 12:53 PM
Norman's Avatar
LORD VADER Moderator
How about a Wally world schwinn. I don't like to mount the engine by drilling the frame sometimes you just about have to and on this bike I had to make a different intake manifold.
Old 01-21-2008, 08:05 AM
Manufacturer/Dealer
Nice install.....I didn't thing the engine would get in there but apparently it does!
Andrew
PS - I like the "shorty" manifold....Does it seem to run any differently than the stock
manifold?
  #9 (permalink)
Old 01-21-2008, 01:40 PM
Norman's Avatar
Andy
It is a very tight squeeze and I did make the manifold which was easy enough. I also did some grinding on the air cleaner(shaved off the teeth on the bottom) and changed out the float bowl(Dax engine) this carb had a drain on the float so I swapped out with another one off one of my bikes. I also had to use the dremel on the clutch cable mount trimmed it to clear the float bowl. And I drilled the frame for the front mount. The exhaust is also bent a little to clear the frame. O yes I massaged the rear frame where the top chain run is. A hammer and brass punch and a beating fixed that. I also had to change out the brake, derailler front and rear derailler cables. They were on the top frame rail. last was different straps to mount the fuel tank.
Performance wise no change found using a short manifold all tho this bike isn't broke in yet. I plan on selling it so some lucky person that just has to have one. I've had a bunch want it but no ones came up wit the cash yet.
  #10 (permalink)
Old 01-31-2008, 07:46 AM
Ilikeabikea's Avatar
Talking Re: What kind of mountain bike for a bike engine?
Hey Norm, I have a bike that looks almost exactly like that one. Mine has a cooler looking bend in the exhaust though. Teresa still ain't rode it though. Maybe after this snow melts......................
http://bdconner.com
Similar Threads
Texas law for engine assisted bicycle Norman Laws and Legislation 28 06-04-2008 12:22 PM
my mountain bike soon to be motorized CRUISER Pictures and Videos 16 05-03-2008 11:21 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
Sprocket Installation - Bicycle Engine Kit CRUISER Motorized Bicycle General Discussion 13 01-29-2008 05:54 PM
Motorized Bicycle Engine Oil - 2 cycle Pre Mix Pablo Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 0 12-29-2007 03:38 PM
