What kind of bike would you recommend?
Discussion at Motorized Bicycle Engine Kit Forum in the Motorized Bicycle General Discussion forum. Hello I have the 80cc engine, and I have it on my mountain bike. It is kind of a cheap ...
Old 03-16-2008, 12:17 PM
Motorized Bicycle Builder
Default What kind of bike would you recommend?
Hello I have the 80cc engine, and I have it on my mountain bike. It is kind of a cheap bike and I'm thinking about updating it. It doesn't necessarily have to be a mountain bike. I was wondering what bike is a good fitting one for the engine and a nice riding one.
- Thanks
Shawn
Old 03-16-2008, 12:26 PM
CRUISER's Avatar
ADMINISTRATOR
Default Re: What kind of bike would you recommend?
us older guys like the cruisers. some stretch some regular. you can sit up straight and they have a really comfortable ride with the ballon tires and a springer front end really makes it nice or shocks. i have came to the realization that 99% of the frames you are going to have to do a little work to get the bicycle motor fit properly. so the way i would do it is find one you like that is comfortable and go for it. welcome to the forum shawn! glad to have you with us
http://stockmarketcats.com/
Old 03-16-2008, 12:31 PM
deacon's Avatar
Hey I'm older than most of the people here and my bike isn't really comfortable. My only requirement is that it have a big seat for my big butt. I can live with the rest, but I don't do long rides. Ten miles is about my longest so far.
Old 03-16-2008, 12:43 PM
Motorized Bicycle Apprentice
you can find all kinds of bikes . theres a website called property room.com this is where the police dept auction off all the stuff they seized and the sell bikes like 20 in a bunch for real cheap and they always have alot of late 80s cruisers and they work great. zoomcat
Old 03-16-2008, 12:45 PM
Thanks for the advice!! I appreciate it.
Old 03-16-2008, 01:22 PM
Norman's Avatar
LORD VADER Moderator
Yard sales and second hand type stores are a good place even the city dumps for the older style of frames but a welder will make the hard ones fit. One of the guys even fitted a full suspension bike with an engine its very cool more work than I'm willing to put out for a bike. check out the bikes here and you will get ideas to help you get going.
Welcome to the dark side of motorized bicycling.
One important thing brakes are very important the side pull type seem to work the best as they apply more power and have the biggest pads I don't have a disc braked bike but I'd bet they are very good. Your levers need to be mated to the type of brakes you are going to use if you build your own the old style pinch levers will not work very well on the newer side pull levers they have a diffenent geometry built onto them and will make it a booger if you get the wrong levers on the wrong style brakes.
Norman
norms-iron-works.tripod.com
Old 03-16-2008, 05:40 PM
Bikeguy Joe's Avatar
Genius Visionary
Keep in mind these engine kits are made to fit the old diamond frame bikes the best, most older or older style cruiser frames are suitable as well.
I did note that at least in my case, the diamond frame bike was smoother, with less engine vibrations being transmitted to the seat/bars.
Old 03-16-2008, 06:20 PM
deacon's Avatar
In my case I have a golden rule.... cheap is better... Gears look cool but how often do you actually change your gear in a motor bike.
  #9 (permalink)
Old 03-16-2008, 07:44 PM
Good brakes are the Key. You need really good brakes. A really good front and rear brake. Everything else is second. Titan is coming... Enjoy the ride...
visit www.thatsdax.com for more !!
  #10 (permalink)
Old 05-25-2008, 05:17 PM
fairracing31's Avatar
Taken from Zippys
Most 24" or 26" bicycle with diamond frame and horizontal top tube should have sufficient space to mount motor.
At least 12.5 inches running along the seat tube from the top of the bottom bracket to the bottom of the top tube.Tubing size from 1-1.5inches on the both the seat and down tube. Plus or minus 70deg. above the bottom bracket between the down tube and the seat tube. Inner distance between pedals needs to be greater than 4.5 inches in width to clear the 4.5inch wide motor.
Instruction Manual - Gas Powered Bicycle Engines, Motorized Fast Bicycles, Motor Gas Engine Bicycle, Bike Conversion Engine Kits, Motor Assisted Bike Engines 80cc and 49cc, Peddle Start Motorized Bicycle Engine and more!
Advertisers
